Will anybody interest in stamp size ccs module?
Old 16th February 2014, 01:32 PM   #21
euro21 is offline euro21  Hungary
This is my revised version.
Old 16th February 2014, 02:26 PM   #22
Sorry I forgot the picture.
Old 16th February 2014, 02:48 PM   #23
Gary P is offline Gary P
Gary P's Avatar
Circuit is looking good. As has been mentioned earlier, keep the gate stopper resistors close to the MOSFET as you have drawn the schematic.
My recommendation is to have the zener protection diodes connected directly between the source and gate terminals. Move the anode of the zener diode to the junction between the gate of the MOSFET and the gate stopper resistor.
Reason is if you are probing around in the circuit while energized and connect your meter lead to the gate of the MOSFET the lead capacitance is enough to create a voltage spike across the gate stopper resistor that can blow the gate of the MOSFET.
The reason I mention this is I've blown up a few CCS's before realizing this detail. The higher the operating voltage the better the chance of letting out some of the magic smoke in the MOSFET if the protection zener is configured as shown in your latest drawing.
http://www.pimmlabs.com/
Old 16th February 2014, 03:33 PM   #24
LinuksGuru is offline LinuksGuru  Europe
Reverse leakage current for these Onsemi zenners seem to be too small to affect MOSFETs, so its OK.
For testing purpose I would recommend to build separate pads with hole D ~ 1 - 1.2 mm. It's much convenient then touching component's leads, and prevents probe slipping.
Old 16th February 2014, 03:54 PM   #25
ctaudio is offline ctaudio  United States
I'd suggest placing R5 at a location that is easy to probe. It makes setting and checking the current more convenient.
Old 16th February 2014, 05:31 PM   #26
Hi, sulcorebutia,
1) Do you plan to include multi-turn trim pot on the CSS add-on board?
2) What is approximate date of final product shipping?
Old 16th February 2014, 06:01 PM   #27
sulcorebutia is offline sulcorebutia  Hong Kong
Originally Posted by LinuksGuru View Post
Hi, sulcorebutia,
1) Yes
2) No nothing confirmed yet.
Do you happen to know any free software that make/draw PCB layout? If I don't provide the PCB layout, the producer will use his own way to make the PCB and possibly will also ignore our concern like, heat dissipation pad or shortest distance between stopping resistor and mosfet etc.
Old 16th February 2014, 06:03 PM   #28
Gary, thanks for your input. Your experience is extremely vital to this project!!
Old 16th February 2014, 06:04 PM   #29
Thank you euro21!
Old 16th February 2014, 06:38 PM   #30
For the beginning, you can use Eagle Freeware Edition
https://www.cadsoftusa.com/download-eagle/freeware/
Board size will be limited to 100 x 80 mm (4 x 3.2 inches), and 2 layers, that's enough for this project.
You may also try freeware open source KiCAD which is much more powerful then free version of Eagle, but I don't know how mature it is.
KiCad EDA Software Suite - Kicad EDA - KiCad EDA
Will anybody interest in stamp size ccs module?Hide this!Advertise here!
Any interest for a big size enclosure? Minisemi Vendor's Bazaar 3 27th June 2012 03:45 PM
6C33C tube stamp sphinx Tubes / Valves 4 6th January 2008 02:04 AM
PGA2310 - Basic Stamp Troubles ALBQ Digital Source 2 8th December 2004 04:31 AM
PGA2310 + BASIC stamp HooRide Digital Source 4 20th April 2004 07:05 AM
1394 time stamp Akh_Ind Digital Source 3 24th November 2003 01:08 PM
Copyright ©1999-2017 diyAudio
