6080 monotriod amplifier - diyAudio
Old 5th February 2014, 01:55 PM   #1
pioux is offline pioux  France
Default 6080 monotriod amplifier
I discover a problem with my 6080 tube amplifier
1 6080 as monotriod , 2 ECC 88 in entry and one valve GZ 32 for power
I heard a low noise on my woofer and that independent from the volume level and entry selection
Noise may be 50Hertz , i am not sure .
I need to be at 20 cm from the loudspeaker (audax 33 cm 95 db for 1 volt ) to heard that ,
have you an idea about that
capacitor , valve , etc
Schematic is here
Image:17182 3767.jpg - AuDIYoFanWiki
thank's in advance
Old 5th February 2014, 02:23 PM   #2
Tesla88 is offline Tesla88  Italy
Tesla88's Avatar
What happen if you disconnect source? I'm looking for ground loops here
What if you remove ECC88 ?
Also when you switch off the amp (main switch without unplug from socket) the noise fade away or stop immediately ?
Old 5th February 2014, 03:42 PM   #3
I will test
new 6080 dc pp singh santa Tubes / Valves 12 1st November 2010 05:07 AM
Ideas for a simple 6080/6AS7 Push-Pull amplifier sonata149 Tubes / Valves 29 20th August 2010 01:54 AM
WANTED - 6080/6AS7 Based Amplifier baileyler Swap Meet 1 26th March 2008 10:17 PM
6080 / 6AS7G power amplifier cjng74 Tubes / Valves 1 16th September 2007 01:17 PM
Free: 6080 tubes jtsjf Swap Meet 0 21st February 2006 08:40 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
