Am I pushing the envelope too far? Layout concerns. - diyAudio
Old 3rd February 2014, 04:47 PM   #1
Cassiel is offline Cassiel  Libya
Cassiel's Avatar
Default Am I pushing the envelope too far? Layout concerns.
Hi, maybe people can share some experiences on tight packages. Is it OK for the preamp tubes to be that close to the output transformers? Is that power tube too close to the power station? I know that I'm taking risks here but I would like to know how many. 50% chance of success? 20%? None? Am I doomed? Could I get away with this? I'm about to punch holes, some sensible advice needed.
Old 3rd February 2014, 05:02 PM   #2
kevinkr's Avatar
Far too crowded imho.. Would be exceedingly difficult to wire, thermal concerns with the tubes so close together, and potential for magnetic coupling between the two output transformers and between the power transformer and one output transformer.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 3rd February 2014, 05:14 PM   #3
Cassiel's Avatar
No problems about the wiring, yes, it would be more difficult but it can be made. Thermal stress? Oh well, I think the tubes can take it. Shorter lifespan? Oh well, that's OK. But there's one thing you said that concerns me - the possible magnetic coupling between output transformers. I didn't know about that. Is there a way I can check that out before wiring?
Old 3rd February 2014, 05:15 PM   #4
BZed is offline BZed  United States
Way too close. Get a bigger chassis.
Old 3rd February 2014, 05:27 PM   #5
Cassiel's Avatar
Yeah I KNOW it's too small. Irrationality can make you stubborn. I don't want to buy a crappy Hammond chassis. This is a commercial amp:
Old 3rd February 2014, 05:33 PM   #6
Loren42 is offline Loren42  United States
Originally Posted by Cassiel View Post
...I don't want to buy a crappy Hammond chassis. This is a commercial amp:
Then why take a shortcut and cram components far closer than the recommended distances?
There are shops that make chassis to order and they are not crappy.
Old 3rd February 2014, 05:46 PM   #7
kevinkr's Avatar
And there a lot of very nice and roomy Chinese made chassis on eBay for comparatively little money as well. (The quality of the boxes I have bought was quite good and not matched by anything from around here at anything like a reasonable price.)
Old 3rd February 2014, 05:51 PM   #8
Cassiel's Avatar
Because it can be done. Hum is the only problem I'm really concerned about.
I don't want my amp to look Chinese. No disrespect to Chinese people. Oh well, it was some kind of challenge, I'm not too sure about it now. Getting cold feet.
Old 3rd February 2014, 05:55 PM   #9
tomchr is online now tomchr  United States
tomchr's Avatar
Morgan Jones recommends in his "Building Valve Amplifiers" that you allow at least 1.5 envelope diameters between the tubes. But he also points out that the amount of IR radiation received by a target is dependent on how big of a radiating surface the target "sees". As some tubes have anode plates that are essentially a long skinny rectangular box, you can place the tubes closer if you rotate them such that the individual tubes "see" the skinny side of the anode sleeve. This is from one of the first couple of pages in Building Valve Amps (perhaps page 10ish).
That said, many console amps placed the tubes almost shoulder to shoulder. The placement also depends on how much power you're dissipating in the tubes. The important thing is that the envelope and anode temperatures don't get too high...
~Tom
Modulus-86: Composite amp achieving 0.00018 % THD. Damn Good 300B, Novar Spud, 21st Century Maida Reg., Filament Reg., etc.
Neurochrome : : Audio - http://www.neurochrome.com/audio - Engineering : : Done : : Right
Old 3rd February 2014, 05:56 PM   #10
tomchr's Avatar
Don't get cold feet. Either get a bigger chassis or a different layout. How about putting some tubes between the PT and the left OPT?
~Tom
Pushing EL36 ?? Tesla88 Tubes / Valves 19 28th August 2013 03:38 AM
what are you pushing with your chipamp? imaginarytime Chip Amps 21 8th November 2012 02:16 PM
Pushing the limits Regulator maartentje Digital Source 23 28th May 2012 11:27 PM
Pushing 6p14p too hard torrence Tubes / Valves 10 3rd October 2011 03:00 PM
6bx7gt envelope temperature coyotesgator Tubes / Valves 6 12th December 2007 12:48 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
