Tube emulation with transistors
Old 2nd February 2014, 07:29 PM   #1
fireworks is offline fireworks  Switzerland
Default Tube emulation with transistors
Here is an interesting web page with transistor circuits that emulate tubes:
Tube emulation with solid state devices
Has anyone built amplifiers with such circuits ? If so, what are your impressions ?
Also, if you have other links to such circuits, please post them here.
Old 2nd February 2014, 08:39 PM   #2
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
Nice triode
Nice triode
Old 2nd February 2014, 09:11 PM   #3
Thanks, that looks interesting. I'll take a better look later.
Old 3rd February 2014, 10:32 AM   #4
Vincent77 is offline Vincent77  Europe
Vincent77's Avatar
I have built and tried most of these guitar FX and while usable, they don't really sound like tubes.
Old 3rd February 2014, 03:08 PM   #5
speakerfritz is offline speakerfritz  United States
played arounded with the DC biasing of Transistors back in 1980.
Old 3rd February 2014, 05:07 PM   #6
Elvee is offline Elvee  Belgium
Elvee's Avatar
Some ideas here:
http://www.diyaudio.com/forums/solid...ept-c-vac.html
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 3rd February 2014, 05:29 PM   #7
Default What is their sound ?
Vincent77
and others who have tried those emulators in real life, what were your results with them ?
My interest lies in experiencing the "tube sound". I'm thinking of building and/or designing an amplifier using these circuits instead of real tubes.
There are many advantages to doing that including cost, weight since there is no output transformer, etc..
Since I'm interested in a (HI-FI) amplifier, not a guitar one, I think that those emulators might be enough. Obviously, for guitar amp. the emulator should give the same distortion as a tube in the very non-linear regime.
For a audio amplifier, it only needs to be faithful in the "almost linear" regime.
Old 3rd February 2014, 05:32 PM   #8
Originally Posted by Elvee View Post
Elvee,
That's interesting, I had the same idea of amplifying the current output of a tube.
Did you build your circuit and if so, how does it sound compared to the original tube or just tubes in general ?
Old 3rd February 2014, 06:06 PM   #9
stocktrader200 is offline stocktrader200  Canada
My first tube project is successful.
I am building a board for an amp using 12ax7 as the output boosted 100x
I should be able to get 50 Watts out of an E88CC.
The test amp sounds great with no global feedback
Old 3rd February 2014, 06:10 PM   #10
stocktrader,
Is the test amp a pure tube circuit or does it contain a "booster" ?
Also, what kind of booster you will be using ? Is it Elvee's ?
Tube emulation with transistorsHide this!Advertise here!
CA 3080/LM 3886 tube pwr amp emulation metalhead Solid State 2 3rd February 2018 03:10 PM
Tube emulation (pritchard article) Barre Instruments and Amps 7 4th November 2010 01:28 PM
Guitar speakers emulation akis Full Range 7 26th September 2009 07:27 PM
Tube amp semiconductor (FET?) emulation danV Instruments and Amps 11 24th June 2008 09:40 PM
SoundEasy crossover emulation ch83575 Multi-Way 3 26th August 2006 10:17 AM
