diyAudio Sponsor
Old 30th December 2003, 07:42 AM   #1
Default schmatic for the audio section of A Fisher K-14 chassis
I have a pair of output and power transformers from Fisher K-14 receiver chassis's .The outputs are for push pull parallel 6V6's with cathode windings ,and are the size of Dynaco A470 outputs .looking for the print to see if it would be practicle to use them with 8417's or 5881's .
Mark
To be better one must be different ,but to be different is not necessarily better .
Old 1st January 2004, 10:57 PM   #2
The chassis also was called a custom electra
Looking for a Fisher chassis 51 mono amp yspm Tubes / Valves 0 5th January 2009 11:27 AM
Cambridge Audio A1 power amp section schematic? Spev Solid State 2 10th July 2007 08:57 PM
hum in fisher 800c phono section slhoward Tubes / Valves 4 4th March 2007 03:43 PM
Schematic for Sony 7700 audio section Smiffy Digital Source 37 12th October 2006 03:00 PM
Fisher 500c - Trouble shooting tuner section ALBQ Tubes / Valves 0 6th May 2004 10:40 AM
Page generated in 0.06699 seconds (67.49% PHP - 32.51% MySQL) with 10 queries
