I recently acquired a pair of KT88 monoblocks. When operating the trannies hum a little (no hum from speakers, just trannies). Both amps have same amount of hum, is this normal? Otherwise great sounding amps.
#2 |
A lot of transformers hum in normal conditions. If they don't get hot and the hum isn't too loud, they are probably fine.
You could try tightening the bolts on them, or putting rubber dampers underneath them, but if its not too loud then just sit back and enjoy the music! |
#3 |
I have three sets and all have a very slight hum when you put your ear next to them. Exercise caution when doing this as a hot tube can result in burned ear.
J |
#4 |
The transformers don't get hot at all, slightly warm thats it. I ran them all day and as they warmed up a little the hum lessened. So after they cooled down I tightened them down and the hum has decreased quite a bit.
Burned what bias do you run yours? The fellow I traded these from indicated 50ma, but I find 55ma sounds better and the company suggests 60ma per tube. He also installed a choke under the deck to save tube life. Only mod done and they operate 100%. |
#5 |
On the actual KT88 versions they recommend 120mA. I run about 110mA in hope of prolonging the output tubes. On my 8417 conversions that I use either 6550's or KT 88's in I run 100mA. In actual distortion tests the higher bias will lower the distortion somewhat.
J |
#6 |
What type of rectifier do you use ie. brand? The fellow I acquired the amps from stated that they were hard on rectifiers and didn't know what brand worked best. One blew a fuse on initial startup, but hasn't since. He recommended a variac to ramp up voltage?
#7 |
lpd
My quicksilvers use either NOS GE 5AR4's or Sovtek brand. Mine have a slight modification in the power supply which involves adding some 1N4007 diodes. These diodes take the brunt of the load and the rectifiers smooth out the peaks. The result is nice bass without the worries of arcing of the rectifiers. If you do a search here you will find several topics on Quicksilvers and there will be a power supply schematic of the modification there. Hope this helps! J |
#8 |
Hey what size and type of fuses does your KT88 amps use? Mine has 3 amp fast blows and one blows out from time to time if I turn on the amp too quickly. Would a slow blow fuse be appropriate?
Thanks Peter |
#9 | |
diyAudio Senior Member
Frank |
#10 |
If you have a good digital volt meter ,check your ac mains to make sure that the dc level is 1 volt or less . Hi dc levels will make the core laminations buzz .
Mark
To be better one must be different ,but to be different is not necessarily better . |
| Quicksilver | lpd | Tubes / Valves | 10 | 9th March 2009 02:55 AM |
| Quicksilver conversion | lpd | Tubes / Valves | 5 | 4th March 2008 10:38 AM |
| Quicksilver rectifier | dreaded 42 | Tubes / Valves | 2 | 8th November 2004 09:51 PM |
| Quicksilver 8417 | dreaded 42 | Tubes / Valves | 4 | 4th September 2003 11:14 PM |
| Problem with Quicksilver amp | Original Burnedfingers | Tubes / Valves | 82 | 21st March 2003 11:20 AM |
