Could this tube be good for audio ? - diyAudio
Old 11th January 2014, 02:41 PM   #1
el156 is offline el156  Portugal
el156's Avatar
Default Could this tube be good for audio ?
Hi !
I have some of this CF3 pentodes ...does someone know by this curves if it could be used for áudio ?
Old 11th January 2014, 02:51 PM   #2
the_manta's Avatar
It's a remote cutoff tube which has a variable µ, so NO. You could try it in the 10mA range where it is abit more linear. But it is still not optimal.
Leave it to the radio enthusiasts for restoring and rebuilding. Many better tubes are around.
Терпенье и труд все перетрут
Old 11th January 2014, 03:13 PM   #3
el156's Avatar
Thanks...i dont know what to do with them, i have some of them NIB and sealed, maybe someone here needs some to rebuild an old radio, since i dont work with rádios...
Old 11th January 2014, 06:02 PM   #4
DF96 is offline DF96  England
Put them on ebay so the ancient wireless people can access them.
Old 11th January 2014, 09:22 PM   #5
Banned
Actually people interested in ancient wireless devices are more interested in mirrors that can be used for heliographing.
Also ancient Greeks could often send messages up to 100 miles away by the use of multiple beacon fires.
Perhaps this was the first cellular network?
Old 11th January 2014, 09:23 PM   #6
Miles Prower's Avatar
Originally Posted by el156 View Post
Hi !
There are a lot of potential audio "sleepers" out there. If you look, maybe you can find a really good audio loadline.
However, I would question why do that? These thingies are OLD, so why use them for a new project when you already know the existing stock will only be depleted?
If you have a few, then E-Bay them and you'll have enough to get some decent newer types more suitable for audio usage, and with a larger stock available. That's one of the good things about those much-maligned "Tee-Vee T00bz": there are a lot of them still out there, waiting for projects.
As the OP said, leave these CF3's to the antique radio restorers. They'll thank you for that.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 12th January 2014, 11:15 PM   #7
Refugee1's Avatar
I will put a link on one of the radio sites for them as they are from the RF side of radio and will not work all that well for audio.
They would usually be seen in sets with wooden cabinets and very early TVs.
Old 13th January 2014, 11:59 AM   #8
el156's Avatar
I also have some of this ones, maybe they could be usefull for someone who works in old rádios restoration. they are C/EM2 magic eye. i am sure they are quite rare tubes.
Old 14th January 2014, 01:22 AM   #9
Refugee1's Avatar
I will make a note and pass it on.
Old 14th January 2014, 03:05 AM   #10
aardvarkash10's Avatar
I'd be keeping the magic eye tubes myself... VEry cool and can be used in a wide variety of devices including audio
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Which tube Rectifier is good enough for 5902 tube amp ? calico88 Tubes / Valves 14 30th July 2011 06:15 AM
Good books or videos on audio production, audio engineering, or audio editing tunks14 Everything Else 0 15th April 2011 11:00 PM
PP Tube Biasing, how good is good enough? TheGimp Tubes / Valves 3 25th October 2009 07:24 PM
Good (tube) audio shows in the US? vax9000 Tubes / Valves 0 16th March 2008 05:11 PM
tube 8416 good for audio ??? Bernhard Tubes / Valves 4 9th January 2004 11:37 PM
Copyright ©1999-2017 diyAudio
