Output Transformer for SE / headphone amp
Does anyone know where I can get an SE output transformer with 5k primary and 8-16-32-150-300-600 secondaries ?
I want to be able to use my 55 ohm AKG headphones and some 600ohm sennheiser headphones but I also want to be able to play some 8-16ohm single driver desk top speakers.
I could have Edcor custom make them but before I do I'd like to find out if they already exist. The trans would be something like this from DHTrob.
http://www.dhtrob.com/schemas/gallery/photos/HeadPhone/CV4079 SE TX Wiring.GIF
How many watts are you shooting for? I'm working on a flea-watt design with 6y6's and wanted to do something similar but I've run in to the same issue. While it isn't hard to find something for 8-16-32 speakers, finding something that includes 150-300-600 is more difficult.
Remember also that the reflected impedance is a function of the load, not something intrinsic to the transformer. If you can find something with the right ratios, you may not need as many output taps.
Mark,
I ordered a pair of SE OT for Jack at ElectraPrint. It is only 2W at 25Hz, 35mA gapped, and I measured 380 ohms DCR primary and 6ohms DCR each secondary. I asked for two 32 ohms secondaries (series is 128 Ohms, parallel is 32 ohms). You can order with two or more secondaries of 8 ohm. This way you can get 1x8 (parallel), 4x8(parallel-parallel), 9x8(parallel-series),, 16x8 ohms (series). I believe that having non-tapped secondaries will offer a more consistent frequency response. In my case I have 26Hz-30kHz(-1dB) for 32 ohms and 29Hz-35kHz(-1dB) for 128 ohms.
Best,
Radu
