I am not sure what best bias is for these.
they sound real warm but a bit compressed and sluggish on the bottom end.
I am using these in this amp. with 12au7 drivers and KT77 power.
DIY Single-Ended KT88 / 6L6 / EL34 / 6CA7 Tube Amplifier
What should they be biased at? How does it sound now? What amplifier?
Here is the datasheet if you don't already have it.
http://www.google.com/url?sa=t&rct=...evvNIb_ohOr9NybhEvyRW1g&bvm=bv.59026428,d.b2I
Yeah I saw that thanks. I am running in triode and just not sure
what kind of voltage would be best for these.
the SED that I have been using had 424v plates and 35v cathode and sound
great. putting these in I get 434v plate and 33v cathode.
I don't know what is the optimal bias point for that tube but you are in the right ballpark. Just listen to it for a number of hours to see if the tubes break in and the sound changes.
Don't go chasing cathode resistor values right now. It could be that tube is just not right for you but give it some time.
Thanks for the feedback.
- Tubes / Valves
- Gold Lion kt77 bias help?
