Old 27th December 2003, 09:05 PM   #1
brsanko is offline brsanko  United States
brsanko's Avatar
Send a message via MSN to brsanko
Default AC coupling
how do I know what size caps to use for AC coupling
PASSIONN
Old 27th December 2003, 09:31 PM   #2
Hi
It would depend on the impedance of the following stage, and your lowest frequency of interest.
An example, if you have a DC input impedance of say 100k, and Flow of 10 Hz, you need a capacitor of:
1 / (100000 * 10 * 6.28) F = 0.000000159 F = 159 nF
Recalculate according to your particular values
Old 27th December 2003, 09:34 PM   #3
brsanko's Avatar
Default thanks
thank you that was just the formula I needed I've been reading Bruce Rosenblitz's book and while it's a great book there were a few details that were just left out
PASSIONN
Old 27th December 2003, 09:40 PM   #4
I can give you a little bit of additional advice, calculate for the lowest acceptable frequency, not the highest.
So if your speakers fall off at say 30 Hz, but your input DC spike you want to remove has a frequency of 2 Hz, you should settle for 5 Hz rather than 25 Hz. Just to preserve as much of the low frequency phase accuracy as possible...
Old 27th December 2003, 09:42 PM   #5
brsanko's Avatar
Default cool
ok I'm really new to this so what would cause a DC spike and how would I know about it
PASSIONN
Old 27th December 2003, 09:55 PM   #6
It could be from switching on the preceding apparatus, usually this could result in a DC spike, in other cases it could be normal thermal drift, in the latter case the frequencies would usually be very low, like 0.2 Hz.
In the switching on case, the f requency ddepends on the time it takes to charge the PS capacitors, and that in turn depends on the size of caps, and the power capability of the charging transformer.
Old 28th December 2003, 04:52 AM   #7
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
I ususally just go with old circuits- they used plenty of 0.22uF and 0.47uF in the mullard/RCA manuals, so they must be pretty decent values...
DC thumps are pretty rare, unless your power supply is on the edge of oscillation. Not much of a worry IMHO
Old 12th October 2011, 07:30 PM   #8
Default Ac coupling capacitor value
Originally Posted by Lars Clausen View Post
Hi
In my simple understanding of electronics, I recall a rule of thumb about RC time constants:
1 Farad : 1 Ohm : 1 second
or
1uF : 1MegOhm : 1second
which would mean , for 100K input impedance
10Hz response would require 1uF cap.
My situation has 10K input impedance, si I would be looking at 10uF film cap. (ouch)
Frankly, I like the 2pi (6.28) term in there, because it would give me a smaller capacitor, but then, what is wrong with my understanding of this time constant rule of thumb?
Old 12th October 2011, 07:40 PM   #9
Alastair E's Avatar
Why is your input impedance SO low...?
Can not the grid-resistor of the input stage be changed...?
Das Beste Oder Nichts
Old 12th October 2011, 09:01 PM   #10
kevinkr's Avatar
or
Try this: RC time constant - Wikipedia, the free encyclopedia
And this if you are brave: Time constant - Wikipedia, the free encyclopedia
Avoid the issue (my choice ): http://www.sengpielaudio.com/calcula...meconstant.htm
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Coupling cap before or after pot? sharpi31 Parts 11 26th May 2008 06:02 PM
Coupling Cap 220µF - the best is... Alfetta87 Digital Source 8 22nd October 2004 11:26 PM
ESP P3A coupling Brownlow Solid State 1 30th August 2003 08:46 PM
Coupling cap Raka Chip Amps 11 9th June 2003 01:06 PM
What does coupling mean? EternaLightWith Tubes / Valves 53 5th January 2003 09:35 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 20.00%)
Copyright ©1999-2013 diyAudio
