designing SS power supply
Old 28th December 2003, 10:45 AM   #11
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Talking mili mili mili........
It's Frank's "American" side coming out
Old 30th December 2003, 03:14 PM   #12
richwalters is offline richwalters
richwalters's Avatar
Someone's taking me on here.....come on.......who says SS isn't on for HV amp power supplies?.....HP have been using this for decades in their test equipment and so have I and not one has come back due to duff PSU's. Do the physics and there's nothing wrong with them. As for SS regies changing the sound sonically, if they are put in the right place <simply.. No>
rich
Old 30th December 2003, 03:38 PM   #13
miguel2 is offline miguel2  Portugal
Well, I made a really sweet psu for a preamp sometime ago. Donīt recall the rectifiers, but I used after a 4.7uF film, 10k resistor, 4.7uF film and a pass transistor made the rest. Very nice indeed. And a 4.7uF near the tubes.
Miguel
Old 30th December 2003, 06:34 PM   #14
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Well, I have been smelling something odd in Frank's direction...
Come on Frank, don't bogart it.....
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 30th December 2003, 06:48 PM   #15
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
I did say:
Just my opinion...
O.K.....I'll leave you to it if you promise me not to use those mF symbols...
Frank
Old 30th December 2003, 06:57 PM   #16
dhaen's Avatar
Default Back on topic...
Designing PSU's for valve's is no different than for anything else. Only the component values vary, as described by the previous posters.
Perhaps the main change is that chokes become practical, both in LC and CLC arrangements.
Here is a link to the most commonly used and free PS simulator:
PSUD2 Play with the simulator until you feel comfortable. It'll do SS and valve recifiers.
If you have a PC it'll run. If you have a Mac, contact me.
IMO Valve rectifiers win, if only because they've got built-in soft-start
Old 31st December 2009, 10:38 AM   #17
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Originally Posted by brsanko View Post
anybody now where I can find some good info on how to design a SS power supply for a tube amp.
powersupplies
this is very informative, i am hooked to the full wave voltage doubler circuits of patrick turner...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 31st December 2009, 11:02 AM   #18
Brit01 is offline Brit01  United Kingdom
I've had a few blown 1N4007 diodes. I would opt for the 3A diodes.
If you've got your mind set on SS then I would include a good CCS, (even with a valve rectifier).
Just completed my first plate CCS with a pentode and it totally tranformed the music. I mean dramatically IMHO.
Ok I lose lots of voltage through a valve CCS but depends what you are driving. Just a 6N1P was my case so efficiency wasn't an issue.
Yep this is a great tool well recommended.
Old 31st December 2009, 11:09 AM   #19
TonyTecson's Avatar
the virtue of the full wave "voltage doubler" as espoused by Patrick Turner is that power transformer design is very simple and easy, none of those 400-0-400volt windings of tube rectified power traffos that required more attention to insulation requirements...
Old 31st December 2009, 12:47 PM   #20
On Hiatus
SY's Avatar
The downside of voltage doublers needs to be recognized, though- worse load regulation.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
designing SS power supplyHide this!Advertise here!
help with designing a power supply zvir Power Supplies 1 31st March 2009 09:26 PM
Designing power supply for class D amp darw82 Power Supplies 1 3rd December 2006 07:24 AM
Designing secondary side power supply darw82 Power Supplies 10 10th August 2006 09:05 AM
Power Supply Designing using LM317, RC-snubber okina Power Supplies 4 12th September 2005 02:17 AM
Designing a LC power supply Badge Tubes / Valves 5 27th July 2004 03:26 PM
