5AR4 PSU - diyAudio
Old 1st January 2014, 05:50 PM   #1
MFF is offline MFF  Portugal
Default 5AR4 PSU
hello guys,
I am designing a power supply for an amplifier, but I have some doubts about the calculation for Minimum Limiting Resistance (RLIM (min))
Rt= Rs + (n^2)* Rp
Where:
Rs = DC resistance of one half of the transformer secondary winding.)
Rp = DC resistance of the transformer primary winding.
n = Secondary to primary turns ratio (equal to the secondary voltage divided by the primary supply voltage).
Can someone please confirm, if my calculations are correct, in this configuration I have 250V per plate right?
The limiting resistor per plate at 300V is 75 ohms, by my calculation I have 133 ohms therefore no need to place a resistor. Assuming my calculation is correct.
Please see files in attach.
Thank you guys for the help
MFF
Old 1st January 2014, 06:22 PM   #2
euro21 is offline euro21  Hungary
"Rs = DC resistance of one half of the transformer secondary winding."
Why "one half"?
HV secondary is 250V+250V= 500V AC, with 42.43R (correct?) DCR.
Without SS diodes this is the half wave rectifier.
Old 1st January 2014, 06:24 PM   #3
pmillett's Avatar
The secondary is a little confusing. Is it 2x 250V (500V total)?
If so... I think "N" is also per plate, not total, so should be 250/240...
Pete
Old 1st January 2014, 07:25 PM   #4
Pete
Hi Pete
Yes is a 2X 250V total of 500V
you're right is 250/240 so after recalculating we have TR= 21.2 + 1,08 x 5,2
RT= 26,8.
As we have 250V per plate and by the datasheet of the 5AR4 the minimum for 300V per plate is 75ohms so I need 75 - 26,8 = 48,2 ohms resistor I am, right?
Thanks for the help
MFF
Old 1st January 2014, 07:28 PM   #5
Why "one half"?
cheek this link
The Valve Wizard
Old 1st January 2014, 07:40 PM   #6
pmillett's Avatar
Originally Posted by MFF View Post
Hi Pete
RT= 26,8.
Thanks for the help
MFF
That seems about right. It will drop your B+ voltage a bit...
Old 1st January 2014, 08:09 PM   #7
will be around 14V.
I am taking the high voltage B+ from the CT of the 5AR4
filaments winding, this way we have less noise from the 5AR4 filaments into the B+ . this is correct?
MFF
5AR4 @ 250mA scott17 Tubes / Valves 24 26th February 2012 07:06 PM
Richardson 5ar4 Davec113 Tubes / Valves 13 4th August 2009 03:46 AM
bad 5ar4? sturmj Tubes / Valves 2 11th February 2009 07:09 PM
Got 5AR4 For Sale? john65b Swap Meet 0 3rd April 2008 07:59 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
