Budget PP Iron: Transcendar or Edcor?
Old 31st December 2013, 04:53 PM   #1
needtubes is offline needtubes  United States
Default Budget PP Iron: Transcendar or Edcor?
I am looking for push-pull 8k:8 transformers that will give good full-range sound at an output of around 5 watts. My choices seem to be Edcor CXPP10-MS-8K or Transcendar. Both are good for 10 watts and are the same price. Both claim full range frequency response.
Does anyone have any experience with either of these?
Thank you
Old 31st December 2013, 05:10 PM   #2
rmyauck is offline rmyauck  Canada
The Dynaco replacement Z-565 cloned transformers from the ST/SCA -35 are a bit more than budget from 3 available different sources are really well regarded so worth the extra $. The Magnequest is exactly original with 8 & 16 ohms secondary taps and the Triode Electrics & Dynakit parts version have different 4 & 8 ohm taps.
All are rated for 17W giving plenty of bandwidth at lower powers and they all have the 25% UL taps for EL84/6BQ5 tubes. They are all rated at 8K primary.
Old 31st December 2013, 08:07 PM   #3
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
I'll spare you the elaborate explanation, but I'd be inclined to go with the Transcendar's.
Old 31st December 2013, 08:37 PM   #4
fullrangeSR is offline fullrangeSR  Canada
+1. They're really well done.
Old 31st December 2013, 08:53 PM   #5
sootboots is offline sootboots  Canada
Another vote for Transcendar
Sent from my iPhone using Tapatalk
Old 31st December 2013, 09:01 PM   #6
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Budget Iron for Low-Power SET
thought I was getting a dejavu
sometimes we know very little, and sometimes we know too much
Old 1st January 2014, 03:53 AM   #7
kstagger is online now kstagger  United States
kstagger's Avatar
I've used Edcor, and the finished product is good, but the wait time of 5-6 weeks can drive me crazy.
Old 3rd January 2014, 08:14 AM   #8
jerrys is offline jerrys  United States
Banned
Default edcor or transcendar??
I haven't found any transformer brand that beats Edcor in terms of quality versus price, which is really what it boils down to for most of us unless you have loads of cash to throw around. I have built more amps than I can count at this point, using new and vintage output transformers. I'll wait on Edcor. The quality, cost (savings) are worth the wait. I have built with Dynacos, Hammonds, Edcors, Fosters, and some other brand I don't recall. The Edcors sound better than ALL of them.
Old 6th January 2014, 11:53 PM   #9
SandyG is offline SandyG  United States
SandyG's Avatar
I have had great luck with Edcors as well. I have used them in every amp I have made so far except for the Quad KT88 amp (Used Heyboer), and still used their chokes as they were a good value. I can't comment on how they sound vs other brands, but they are very nicely finished and you can order them most anyway you want them. Every one is made to order so you can have it your way. The down side is it takes about a month to get them. First thing I do on a new project is figure out the transformers and order them up from Edcor and by the time I'm ready to build they are showing up.
I have some from Heybor and while good value and can support really large cores for high power amps, they were sinfully ugly when I opened the box. They were easy to clean up but the Edcor's are perfect when you open the box.
Those are the two vendors I have used and would not hesitate to use either again.
Sandy
Working on electronics www.EZ260.com and cars www.GTSparkplugs.com
Budget PP Iron: Transcendar or Edcor?Hide this!Advertise here!
Budget Iron for Low-Power SET needtubes Tubes / Valves 11 24th December 2013 08:53 PM
2A3 SETs with Edcor Iron kmaier Tubes / Valves 4 25th July 2011 05:52 PM
Transcendar Budget SE Transformers wrenchone Tubes / Valves 15 12th April 2008 09:53 PM
FS: Edcor iron package for SimpleSE and related amps jrebman Swap Meet 0 17th March 2008 06:28 AM
Edcor amplifier --> 6l6 PP guitvinny Tubes / Valves 2 13th May 2006 03:18 AM
