ECC81 or 83 or 85 or 88 ???
Old 26th December 2003, 03:44 PM   #1
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
Question ECC81 or 83 or 85 or 88 ???
which of them should be preferred ? Best sound ?
I like to use them in a DAC output stage and know they are more or less exchangeable.
Also how do I see if a plate is smooth or what
Bernhard
Old 26th December 2003, 03:57 PM   #2
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Since it's for a DAC I'd prefer the ECC88 based on electrical properties.
A smooth plate is usually rather long and completely flat, like a sheet of paper if you like.
That's a term often used to distinguish between those and the more commom ribbed type plates.
TFK used both types for their ECC83s, some Philips ECC81/2/3s where built with smooth plates as well.
Nowadays the only manufacturer I know of building their small triodes like this is EI in former Yugoslavia.
Frank
ECC81 or 83 or 85 or 88 ???Hide this!Advertise here!
7 pin ECC81. Cassiel Tubes / Valves 9 16th February 2009 02:00 PM
Ecc81 12at7 316a Swap Meet 0 30th May 2008 11:51 AM
Test of ECC81 to 83 Hojvaelde Tubes / Valves 1 11th January 2008 01:02 PM
ECC81 Tobruk Tubes / Valves 6 25th April 2007 02:47 PM
ecc81 gianis Swap Meet 0 12th June 2006 08:44 PM
