Old 29th December 2013, 04:54 AM   #1
ProfGriff's Avatar
Default Pop goes the bias cap.
I was firing up my modded ST-70 after changing tubes, and let some smoke out.
These are the guts of a 100uf 100V Sprague Atom. Time for a little clean up and ordering parts!
Griff
Old 29th December 2013, 07:04 AM   #2
astouffer's Avatar
Caps don't usually explode unless the voltage is too high. You might want to take a few readings after the new cap is installed.
Old 29th December 2013, 07:49 AM   #3
SY's Avatar
Or the cap is backward. Or the rectifier is backward or shorted.
"The way to deal with superstition is not to be polite to it, but to tackle it with all arms, and so rout it, cripple it, and make it forever infamous and ridiculous."- H. L. Mencken
Old 29th December 2013, 08:02 AM   #4
M Gregg is offline M Gregg  United Kingdom
M Gregg's Avatar
Or G2 to G1 short,
If its in fixed bias.
Depends what the cap is being used for? If its in the B+ it could be over voltage.
Low current draw on the B+ rail giving over voltage.
Or as above rectifier fail etc.
So you need to tell us where in the circuit the cap is connected? (and voltage rating)
M. Gregg
What is the sound of one hand clapping?
Old 29th December 2013, 09:08 AM   #5
Miles Prower's Avatar
I'm figuring cathode bias resistor bypasses. Something in there caused excessive current, and too much voltage across the bias resistors. You need to find out what caused that. Might want some higher voltage bypass capacitors too.
(George poofed cathode bypass capacitors before trying for eleven a couple of times.)
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 29th December 2013, 02:45 PM   #6
lhgin is offline lhgin  Malaysia
Poofed after changing tubes? Did you replace with the correct tubes?
Tube Rules! http://jandkaudiodesign.blogspot.com/
Old 29th December 2013, 04:47 PM   #7
ProfGriff's Avatar
No, this is the first cap in the fixed bias supply, and was working for 3 years before. The bias was -46V with the controls all the way CC, and this was a 100V part. I cant explain why it blew up.
I have a Curcio auto bias board kit kicking around. Maybe this is a message telling me it belongs in here.
Thanks for the replies.
Griff
Old 29th December 2013, 04:56 PM   #8
Frank Berry's Avatar
Check the bias rectifier. Make sure its good with no reverse leakage.
Frank
Old 29th December 2013, 06:33 PM   #9
M Gregg's Avatar
Griff
Err NO!
It means you need to know whats wrong before you blow the board up as well.
G2 to G1 short what would happen to the bias supply?
Could be rectifier but isn't it strange it was after a tube change?
Then again don't be surprised that the fault has suddenly vanished...if there was an internal short in a tube now blown open.
Check the new tubes for internal shorts with a resistance test.
Check the components in the bias supply and get it working as normal before you do any mods!
M. Gregg
Old 29th December 2013, 07:17 PM   #10
ProfGriff's Avatar
You are right. Good thinking. I will check out the tubes (new Winged C EL-34s) for shorts on my tester. The $5 in parts for a new bias supply would not hurt either.
Thanks and regards
Griff
bias spreader bypass cap Dan Moos Solid State 6 22nd April 2013 03:52 AM
Cap to bypass bias battery dsavitsk Tubes / Valves 4 24th February 2011 11:00 AM
How to calculate bypass cap across bias resistor? Henry8 Solid State 27 14th November 2010 02:20 PM
Bias Cap??? Size??? Zero Cool Solid State 8 19th December 2009 12:35 PM
Cap across bias stabiliser PeteMcK Solid State 22 30th January 2003 12:23 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
