Adding a pre out to amp - diyAudio
Old 27th December 2013, 11:24 PM   #1
monaro is offline monaro  Australia
Default Adding a pre out to amp
Hi guys,
I have a doosie of a question.
I have a kriesler 11 97 (here: http://www.kevinchant.com/uploads/7/...8231/11-97.pdf)
And I want to add a powered subwoofer to the preamp output (which it doesn't have!)
I was thinking of adding a connection at the volume pot but I can't get it to work when I connect it that channel stops working.
The amp does have high level input too but I find lack of bass using them - I think the tube amp filters out the low bass.
Any ideas? I'm not sure if maybe I need to add a resistor to the new rca connection so it doesn't cancel the channel although I'd have thought there would be bugger all signal drawn from the amp given its line level in?
Old 28th December 2013, 05:57 AM   #2
The output of the volume control should be the place but the impedances are so high you really want to add a buffer so that the cable capacitance doesn't affect the internal or external amp response. A cathode follower would do the trick. An FET source follower or a unity gain opamp would also be good.
G
Old 28th December 2013, 07:10 AM   #3
Oh thanks this is great advice. I understand that now - cathode following will stop the connection draining the whole signal. Question is what exactly do I buy and how do I connect it - i've never used one! Thanks!!
Adding pre-out to an integrated amp schubert Solid State 30 1st November 2011 09:57 AM
adding output tubes etc to pre amp pforeman Tubes / Valves 1 2nd February 2009 06:02 PM
Adding Pass through input on my pre-amp RollE2k Parts 3 27th June 2008 03:47 PM
Adding a HP-amp to my pre-amp design rho Chip Amps 3 8th April 2004 07:17 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
