Red Pilot (240) - diyAudio
Old 27th December 2013, 07:09 PM   #1
jackinnj's Avatar
Default Red Pilot (240)
I "improved" the Pilot 240 i had a while back -- it's going to get improved again -- has just been sitting on the shelf for years. Telux multiple LED's in the EL84 cathode lines:
Old 27th December 2013, 11:08 PM   #2
kevinkr's Avatar
How good is the balance in that somewhat funky driver stage?
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 28th December 2013, 12:02 AM   #3
jackinnj's Avatar
The only difference between this and the original is the replacement of the cathode bias resistor with the TELUX led matrix. I am going to guess that R1,2,7 could be replaced by a potentiometer for the purposes of setup.
Old 28th December 2013, 12:29 PM   #4
I have several Pilots but I have no experience with using LEDs for bias. I've been meaning to give them a try sometime.
Pilot amps are highly praised for their sound. The 232 is widely considered one of the best PP 6BQ5 amps around. The Pilot integrateds such as the 240, 245, and 246, are built around the same basic 232 design. I've always found it odd, however, that paraphase inverters (as used in those designs) are generally frowned upon from a technical perspective. Same holds true for the Magnavox console amps, which have a loyal (some would say rabid) following.
My understanding of design and technical detail is, admittedly sorely lacking. And I've heard all the arguments against the paraphase - "not elegant", "not balanced", etc.
I like what I hear with these designs, though. =8^)
. . . Charlie
Old 28th December 2013, 01:00 PM   #5
jackinnj's Avatar
I also have a Pilot receiver pulled out of the recycling bin in our town.
The 240 was given to me by the father of friend but it wouldn't make any noise whatsoever. (Slowly brought it up using a variac.) When I did power it up I discovered problems with the filter caps and some of the resistors were charred and way out of compliance.
5 of the Telux LEDs, should get the bias to the right level, but I'll bench test it first and relate the results.
Old 28th December 2013, 04:29 PM   #6
Cassiel is offline Cassiel  Libya
I'm with you Charlie. PP with a paraphase splitter, best thing I have built. Luckily I ignored all the techies opinions on this subject.
Old 28th December 2013, 04:34 PM   #7
diyAudio Moderator Emeritus
jean-paul's Avatar
One of the most musical sounding driver stages. It was also used by L' Audiophile (Paris) in various amps.
Don't listen to opinions, listen to the amp
It's only audio. Member of the non modular PCB design committee
Old 28th December 2013, 04:51 PM   #8
M Gregg is offline M Gregg  England
Anyone have a link to schematics for:
The Pilot integrated such as the 240, 245, and 246,
Just curious..
M. Gregg
Old 28th December 2013, 05:20 PM   #9
jackinnj's Avatar
http://www.tech-diy.com/TubeDesigns_...0/Pilot240.pdf
Old 28th December 2013, 07:17 PM   #10
You have the diodes connected in shunt (Vd= 1.83-2.67v)? is this rock and roll?
Art
Improve this Pilot 240 (EL84/6BQ5) jackinnj Tubes / Valves 8 12th May 2011 04:40 PM
found tube i like, only small bits of red letter,what tube brands used red lettering? ryuji Tubes / Valves 2 15th April 2011 11:24 PM
Is Red Circuit's Guitar controller Really RED? Paswa Chip Amps 7 20th May 2008 04:48 AM
pilot 264 jaron Tubes / Valves 17 13th March 2006 03:32 PM
irf 240 or irfp 240 for the aleph scu Pass Labs 2 14th January 2002 06:49 PM
Copyright 1999-2017 diyAudio
