diyAudio Sponsor
Old 9th January 2004, 08:57 PM   #31
VictorG is offline VictorG  United States
Thanks for the continued help.
I am almost done assembeling the parts list and things are looking good.
I want to include you in my thinking through, just to double check, the particular hammond i was thinking about using was the 1650F
Specs:
1650F
Audio Watts (RMS) 25
Primary Impedence: 7,600 ct
Max DC per side 128 ma.
Secondary Impedence(s) 4-8-16
"these transformers include 40% screen grid taps for Ultra-Linear operation"
The only reason I am double checking this transformer with you is that y your comments yo seemed to be pretty close to commenting on this peticualr tranny save tat you thought the primary impedence wouldbe 3.5k and you didnt think there was a secondary impedence of 16 avail. Were you looking at another tranny that I am unaware of, or did i just read to much into generalized statements?
Anyway, this transformer is in my range, not bad at all pricewise.
Thanks for the continued guidance. I am going to begin a pcb layout soon (just makes it easier for me)
Brian
Stewie: You there, fetch me the wall street journal. You two! Fight to the death!
Old 9th January 2004, 10:03 PM   #32
Jax is offline Jax  Sweden
7.6k impedance is a little too high for EL34's unless you are going to run them in class B with 800V plate
1645, 1650K or 1650N would be better. If money is tight, go for 1645.
Old 18th January 2004, 06:45 AM   #33
Default Power Supply
Jax-
You'll be happy to know (or at least I am) that i have aquired around 75% of the nessesary parts.
Now for the power supply-
Any thing I should know, or just get the votage through the bridge rectifyer and put some caps in parallel? Let me know what I should do here, as i dont see any info on this componenet of the system.
Thanks,
Brian
Old 19th January 2004, 08:46 PM   #34
As a starter, for the 350V supply:
280-0-280V AC to a fullwave rectifier with 2 1N4007 diodes, a 22uF 450V cap, a 10H choke and a 100uF 450V cap forming a CLC pi filter.
or:
300-0-300V AC to a 5AR4 or GZ34 rectifier tube, same choke and capacitors above. You need a 5V 2A winding for the rectifier heater also.
You can use a 5U4 rectifier tube also but you need 320-0-320V and 5V 3A.
This is for one channel. If you want to share for both, go with the semiconductor diode version.
Jan
Old 2nd February 2004, 05:37 AM   #35
Default last q
real quick, c11 on the schematic is missing a value. rating? Thanks a bunch, almost there.
B
Old 2nd February 2004, 05:41 AM   #36
where would you recommend an output level control? 100ohm pot where? thnx again.
Old 2nd February 2004, 07:06 AM   #37
You can leave C11 out for the moment, it's only needed if you increase the feedback.
You mean a volume control? Just add a pot at the input.
Jan
Common Audio Tubes in standard use Zero Cool Tubes / Valves 10 30th June 2008 04:52 PM
Free oddball tubes! isaacc7 Swap Meet 7 18th October 2007 01:42 PM
Free: 6080 tubes jtsjf Swap Meet 0 21st February 2006 08:40 PM
Common Source versus Common Drain output stages alaskanaudio Solid State 33 27th March 2003 02:04 PM
Page generated in 0.10553 seconds (78.23% PHP - 21.77% MySQL) with 10 queries
