| diyAudio Sponsor | ||
Hi guys
a friend have a little trouble with a WE tube mounted on an old radio. The tube is marked WE13 but I never found data on the web. Another friend have a similar tube named WE23 but seems different. Can anyone help us to find information about this old vacuum lamp? thanx a lot ciao Filippo www.audiofanatic.it |
#2 |
That's a rare one - a side contact tube!
It's a combined triode-pentode, indirectly heated with a 6.3v heater at 1A. I assume it was designed to be a frequency changer for AM bands. Pin connections are: 1 = grid 1 2 = grid triode 3 = cathode (both triode + pentode) and grid 3 4 = heater 5 = heater 6 = no connection 7 = anode triode 8 = grid 2 Top cap (or side cap) = anode pentode I don't know the situation in Italy but in the UK such a tube is virtually unobtainable, so if your friend needs to replace it in his old radio he might have to drill the base out and adapt a 6K8 in its place. I don't have any info for a WE23 though... |
#3 |
On further investigation the WE13 was not designed to be used as a frequency changer, but as as an audio driver and output tube - the anode current of the pentode is 36ma at 250v. Very unusual for a side contact tube to have this configuration - you learn something new every day!
Seasonal Greetings! |
#4 |
Thanks 10000
we try with a 6K8, but it's an hexode-triode, maybe also a simple 6AN8 will be good.... thanx again Filippo www.audiofanatic.it |
#5 |
mmmmm.... 36mA @ 250V? the 6AN8 isn't good... maybe an ECL82-85-86...
#6 |
Information about the WE13 is sparse (I'm checking in Babani's Radio Tube Encyclopedia of 1949!) but the characteristics of the pentode section are:
Va = 250v Ia = 36ma Vg2 = 250v Ig2 = 4ma Rk = 150 ohms Anode imp = 7000 ohms Power out = 4.5w Hopefully this will help you get a good match. |
#7 |
ok, dissipation and load are close to the ECL86
thanks, have a good 2004! Filippo www.audiofanatic.it |
| Tube PSU question | Greyskale | Power Supplies | 8 | 27th February 2008 10:06 AM |
| Tube PSU Question | philipbarrett | Tubes / Valves | 18 | 19th October 2005 12:03 AM |
| What can I do with these? (tube and OPT question) | needtubes | Tubes / Valves | 7 | 8th March 2005 02:01 PM |
| Tube Question, what the....? | Rino odorico | Tubes / Valves | 15 | 11th November 2002 10:14 PM |
| Tube CAD Question | Aud_Mot | Tubes / Valves | 0 | 6th October 2002 04:53 AM |
| Page generated in 0.27610 seconds (28.12% PHP - 71.88% MySQL) with 10 queries |
