Cathode bipass capacitor and transformer impedience
More gut feelings...
Actually on second thoughts, there should be more power transfer with the cathode bypassed. The reasoning is that the Rp will reduce and so less power will be wasted in the valve....
I'm not talking about gain....
The distortion sig will change with the cap to reduce 3rd & 5th, and increase 2nd.:deerman:
diyAudio Senior Member
Joined 2002
Since it's X-Mass....:angel:
With Rk NOT bypassed the AC gain is reduced as degenerative feedback is introduced. Hence distortion is reduced.
Absolute power will be the same but as the Zo is higher with the cathode unbypassed a higher Zprim is preferable.
Cheers,;)
Christmas spirit
Yes, that's the 2H produced by the valve. But the 3H & 5H produced by the valve and transformer is increased.
So power transferred is independent of source impedance? I don't think so.
Of course the Zprim is best to be as high as possible, for low distortion, but not for power.
