spudnik, spudMiG ? - diyAudio
Old 16th December 2013, 06:42 AM   #1
6J7 is offline 6J7
6J7's Avatar
Default spudnik, spudMiG ?
Just finished these monoblocs, driven by an asus xonar D/A converter.
Input transformers are LL1681 (1:13)
It sounds pretty good
Unfortunately I don't see how to remove these coupling caps because of fixed bias and I don't like the idea of cathode bias with that kind of tube..
File Type: jpg Screen shot 2013-12-16 at 08.27.55.jpg (105.3 KB, 481 views)
Old 16th December 2013, 06:55 AM   #2
6J7 is offline 6J7
6J7's Avatar
Another view with meters, they are directly in the path to measure anode current on each plate.
Old 16th December 2013, 07:05 AM   #3
Shoog's Avatar
If you can split the OT primary you can load each plate with a CCS followed by a capacitor before each half of the primary winding. I have used this successfully in one of my designs and it ensures perfect DC balance with grounded cathode and no coupling caps.
Shoog
Old 16th December 2013, 03:58 PM   #4
smoking-amp's Avatar
Looks like some resistors are missing in the feedback arrangement.
I want a Huvr-Board!!
Old 16th December 2013, 07:31 PM   #5
get the Feedback from the primary
M.
Old 11th January 2014, 06:53 PM   #6
6J7 is offline 6J7
6J7's Avatar
Thank you for your input.
No.
This amp sounds fine with Cornwall III's despite the DF a little bit on the low side.
Time to start another spud, this time with GU17 and CFB
Old 11th January 2014, 09:11 PM   #7
seppoa is offline seppoa  Sweden
One possibility to eliminate the coupling cap is to connect the input trafo directly to the grid, and attach the bias to the ground end of the trafo, parallel to a gridleak and a cap to ground. Not sure thou if it will improve the sound, as the signal current passes thru the cap?
Old 11th January 2014, 11:23 PM   #8
Zekk is offline Zekk  Singapore
Hi 6J7... That's gorgeous! A thing of beauty is a joy forever. Love those exotic tubes. Wish to built one but do not have a reliable schematic.
BTW, where did you buy those anode caps?
Thanks for sharing.
Old 12th January 2014, 12:23 AM   #9
lhgin is offline lhgin  Malaysia
1:13 input transformer?
did you manage to measure the frequency response? i'm just wondering if there would be setback with such a high step-up ratio on the input side.
thanks!
ken
Tube Rules! http://jandkaudiodesign.blogspot.com/
Old 12th January 2014, 02:03 AM   #10
The input impedance looks like it is about .29 Ohm? (x4 for differential)
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
