Ruby Tuby at 24V?
Ruby Tuby at 24V?
Old 8th December 2013, 09:23 PM   #1
pdavis68 is offline pdavis68  United States
Default Ruby Tuby at 24V?
I'm building this pre-amp. Yes, I know it's low voltage and won't sound like it would at full-voltage, but it sounds decent at 12V.
What I'd like to know, though is, I have a +/- 12VAC CT transformer. Could I run that circuit from +12 to -12 and just use the -12 where the circuit uses ground (except for PIN 5 of the 12AX7 which would go to the CT obviously, to keep the heaters at 12V).
Obviously I'd need to add a 7912 to regulate the -12VDC. I was thinking of something like this.
Ruby Tuby at 24V?Hide this!Advertise here!
Need help troubleshooting Ruby amp ozzu2000 Solid State 16 26th March 2015 04:19 AM
Tuby TQWP or Derwent BVB Horn? vincula Full Range 4 11th November 2013 03:02 PM
Tuby from SpectrumAudio Hilmar_G Full Range 1 22nd February 2012 05:19 AM
Ruby capacitance sale jackyliu Swap Meet 0 20th July 2011 11:24 AM
Ruby Tuesdays Rockmore Tubes / Valves 15 27th June 2009 08:28 AM
