cheapest output transformer for a SE EL84 guitar - Page 2 - diyAudio
Old 23rd December 2003, 11:50 AM   #11
316a is offline 316a  England
316a's Avatar
Default Transformers
Originally posted by bournville
Tschrama,
The postage on a mains trannie from the UK would be a lot cheaper to the Netherlands than from the US. Try Maplins:
http://www.maplin.co.uk/
They have a mains trannie suitable for your amp - code XP27E - which has a 240v secondary at 100ma and 6.3v at 1.5A. Cost 12.99 (18.50).
I've tried using mains trannies as output trannies in amps before, but I'd only recommend it as an emergency replacement. Frequency response often leaves much to be desired and core saturation is always possible (although not a problem in a push-pull amp).
Some cheap SE outputs
http://www.mc-h.demon.co.uk/xformer.html
http://hometown.aol.co.uk/oldradioparts/oddsnsods.htm
Otherwise butchering an old Dansette record player or reel to reel would be another cheap source
316a
Old 23rd December 2003, 06:59 PM   #12
Yes, if Tschrama doesn't mind used components then he could try the junk shop at Past times Radio. They strip down old valve radio chassis of sets beyond repair and test and sell on the usuable stuff. Mains trannies from 6, and output trannies from 7.
http://www.freeweb.telco4u.net/pastt...es/spares.html
I've bought stuff from them before, and they are nice approachable people. If Tschrama e-mails them his requirements, I'm sure they could sort some suitable trannies out.
316a, before butchering an old Dansette record player, did you see the Dansette radiogram on eBay last week that went for 101? I'd bought the same model about 10 years ago at a junk shop to strip for parts for 2!
Old 23rd December 2003, 10:15 PM   #13
Thanks guys! I am checking all your links.
Thanks and many greetings,
Thijs
SE EL84 output stage? Lingwendil Tubes / Valves 2 29th June 2008 05:55 PM
EL84 for Ipod and guitar thomsva Tubes / Valves 4 2nd June 2008 12:39 PM
EL84 PP output transformer for 6L6 PP class A engels Tubes / Valves 8 30th May 2007 09:45 AM
EL84 Guitar amp questions (long, sorry) Sherman Tubes / Valves 2 6th September 2005 12:20 AM
modify eagle el84 for guitar psychosteve Tubes / Valves 7 17th November 2004 10:58 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
