Transmitting Triode Amps
Old 27th June 2002, 04:37 PM   #31
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Hi Dhaen..
Have you decided about AE tranformers yet?
Bas
Old 27th June 2002, 07:52 PM   #32
dhaen is offline dhaen  Europe
dhaen's Avatar
Hi Bas,
I'm still waiting for clarification from AE about frequency reponse and shipping.
Have been in touch with Triode Dick, who gives a glowing report on the AE product, so as soon as I get clarification I shall order from them: OPT's and driver transf..
Thanks again for the recommendation, I'll pass it on once I have first hand experience.
dhaen AKA JD
Old 27th June 2002, 11:52 PM   #33
Hi Jd,
My chokes should be finished next week, when I'll go to get them I'll see if I can exctract some info from him... ;-)
Bas
Old 28th June 2002, 12:24 AM   #34
dhaen's Avatar
Thanks Bas.
Tell him I'm the one who's asked for the 845/GM70 SE OPT's and the 5K 1:1 high current Interstages.
I'll come and get them if necessary, but I'm not in Holland untill September (IBC in Amsterdam).
JD
Old 28th June 2002, 08:57 PM   #35
dhaen's Avatar
Originally posted by steve jones
Take a look at this:
http://www.expresslighting.com/eltran24.html
An 11.6V/5A@>20khz version was posted on the TubeDIY Asylum, by Par.
I haven't tried 'em yet (probably have to choke filter the output switching noise), but hum should be non-existant with ultrasonic AC heating. And you could throttle/trim the output voltage with a dimmer.
Have you ever looked at the output waveform of one of these?
I looked at one a couple of years ago (that was causing interference). That one's waveform looked like 20KHz (ish) square wave - modulated between 0 and 100% by 100Hz.
Now I don't know whether they all use the same principle, but this one just looked like a bridge rectifier into an oscillator and a ferrite transformer.
If they are all the same, it's a no-go'er.
BTW I would love to be proved wrong on this one!
Old 11th October 2002, 12:04 AM   #36
almarcy is offline almarcy  United States
Default sv572-30 as driver
I am using SV572-30 as driver for Sovtek 2A3. IT is EP 3634-2.
DC filament chokes from EP as well. 277V on the plate, 18 mA. I have the negative pin grounded on 6 volt filament, giving -3V bias.
Sound is OK
Happy Ears!
Al
Old 11th October 2002, 01:55 AM   #37
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Re: sv572-30 as driver
Originally posted by almarcy
Happy Ears!
Al
Welcome to the Forum Al (aka TubeGarden) ... your wit and incisive narrative will be a great addition.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th October 2002, 02:59 AM   #38
Brett is offline Brett
Brett's Avatar
Default Re: Re: sv572-30 as driver
dave
Seconded!
Cheers
Old 14th October 2002, 04:48 PM   #39
dice45 is offline dice45  Germany
, Dave ..
Welcome, Al!
Bernhard
Old 19th October 2002, 02:02 AM   #40
Default Got this 809 I wanna try...
I can't remember where I got it. Only one each, but, with a top cap tied to the IT, it should work
And it only requires 2.5 amps for the filament
Thanks for the warm tube welcome.
Happy Ears!
Al
Transmitting Triode AmpsHide this!Advertise here!
transmitting HD audio/video over RF Daveis Everything Else 2 2nd February 2008 12:57 AM
Opinions of Menno Vanderveen ( van der Veen ) PP Amps, Esp. Super-Triode DrDeville Tubes / Valves 41 11th March 2004 06:39 PM
Super Triode Conection amps - opinions needed Petman Tubes / Valves 2 25th October 2003 02:00 AM
Triode Amps Jack Thomas Tubes / Valves 8 9th March 2003 08:19 PM
Transmitting audio over power line paulb Solid State 3 5th April 2002 09:08 AM
