#21 |
diyAudio Moderator Emeritus
Wow!
The beauty ot this one seems to be that it doesn't need forced air cooling (at reasonable powers). This thing can take as much grid current (75mA) than the usuals can take though their anode (plate). I wonder what the Ra (Rp) is. I notice that the linked company makes OPT's with 30k primaries, so perhaps it's about 10k. If this is the case, it might be difficult to equal the performance (other than power) of the commoner 211, 845, 572 etc, without very special attention to transformer design. Thanks for the link! |
#22 |
Look at Lancroft tramsformers site. They have trannies, and at least 2 designs for the beast there. Supplies are up in the 1500V+ range which makes it a heck of an expensive amp on parts.
http://www.users.bigpond.com/triode/833A1.html Then there's always the GM70, which AudioXpress has an article on about a year ago, and iirc, it was 30W. They are $US50 new from KW Tubes (he's on holidays till end of July). http://kwtubes.s5.com/ Or the GM100. Now this is a man size tube. Almost literally. http://www.vt52.com/diy/myprojects/amps/gm100/gm100.htm Makes the 833A look like a pokemon
#23 |
Let the boasting about size end here!
Yes I know and love the GM70. I'm currently building an SE amp that will run with 845's or GM70's. The trouble with these biggun's is the heater power. Makes hum reduction a "non trivial" problem in SE. Still, it's lucky my speakers are not too efficient. |
#24 |
What are the heater requirements on the GM-70? I might have a cheap slick option to try.
#25 |
They are 20v 3.25A as far as I remember..
#26 |
Take a look at this:
http://www.expresslighting.com/eltran24.html An 11.6V/5A@>20khz version was posted on the TubeDIY Asylum, by Par. I haven't tried 'em yet (probably have to choke filter the output switching noise), but hum should be non-existant with ultrasonic AC heating. And you could throttle/trim the output voltage with a dimmer. |
#27 | ||
![]() Quote:
HF AC heaters were also discussed on Tube -DIY a bit recently. Cheers |
#28 |
I would like to add my cent to this discussion a bit out of topic .
Q: Does anybody order something from vv52.com? Just seeking more info about liability of the seller. Thanks, |
#29 |
#30 |
I ordered some valves (tubes) from Jim de Korts other company http://www.triodes.nl/.
After 2 months and many emails (mostly mine), they eventually turned up. I do not know who's fault the delay was, but it was not delayed in the UK because the package had a Dutch postmark of 2 days previous. Those are the facts. |
| transmitting HD audio/video over RF | Daveis | Everything Else | 2 | 1st February 2008 11:57 PM |
| Opinions of Menno Vanderveen ( van der Veen ) PP Amps, Esp. Super-Triode | DrDeville | Tubes / Valves | 41 | 11th March 2004 05:39 PM |
| Super Triode Conection amps - opinions needed | Petman | Tubes / Valves | 2 | 25th October 2003 01:00 AM |
| Triode Amps | Jack Thomas | Tubes / Valves | 8 | 9th March 2003 07:19 PM |
| Transmitting audio over power line | paulb | Solid State | 3 | 5th April 2002 08:08 AM |
