Monoblock project
Monoblock project
Old 18th November 2013, 10:36 PM   #1
famousmockingbird is offline famousmockingbird  United States
Default Monoblock project
So I am building a pair of monoblocks on a steel Hammond chassis that measures 17" x 10" x 3". The design is similar to the Mullard 5-20 amplifier. I can't fit the choke under the hood so I am going to mount it on top. I went with Edcor iron so the choke looks nice enough to be on top, the blue end bells with the black chassis looks good. I pretty much have my layout done and plan on posting some pics but I have a question about transformer placement I plan on having the cores line up as such:
So the output and power transformer are on the back side of the chassis with the choke up front. The choke will be between the rectifier tube and the preamp tubes. The power tubes will be on the outer side of chassis next to the output transformer.
Does this seem OK? Any advice would be great before I start drilling holes.
thanks
Old 18th November 2013, 10:42 PM   #2
ok so for some reason what I type in edit mode does NOT appear the same in the thread so I will post a picture ASAP
Old 18th November 2013, 11:24 PM   #3
TheTubeAmper is offline TheTubeAmper  United States
TheTubeAmper's Avatar
What tubes are you using?
Read and Follow my posTs at your own discretion, and risk. I'm an Electronics and Audio Hobbyist who likes tube amps too! Please check out my projects at http://thetubeamper.com/
Old 18th November 2013, 11:36 PM   #4
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
From what I read in Morgan Jones book, the choke is the highest emitter of EM fields...that said, it should be tucked into the farthest corner of any chassis, away from everything as much as possible.
__________________________________________________ ____Rick.........
Old 18th November 2013, 11:58 PM   #5
Tubes are EF86 gain stage directly coupled to 12AX7 LTP PI driving KT77 PP/23% screen taps. Rectifier tube is 5AR4.
Old 19th November 2013, 12:01 AM   #6
Thanks I will read up on that and maybe change my layout if it will help.
Old 19th November 2013, 12:01 AM   #7
smbrown is offline smbrown  United States
smbrown's Avatar
I was looking at some of the mono-blocks now on the Audio Note Kits site: ANK Audiokits - The Authority in High End Audio Kits
The choke on the "ledgend" and "interstage" designs seems very close to the interstage, I'd wonder about that. However, it is as far from the input tube as practical. There are other designs, like Sun Audio 2A3 that wedges the choke between power and output transformers, and much closer to input tubes.
Old 19th November 2013, 12:03 AM   #8
smbrown's Avatar
Sorry, the Legend obviously does not have an IT, but power and output are very close. I guess my point is, lots of things are possible, but maybe not optimal.
Old 19th November 2013, 12:27 AM   #9
Eli Duttman is offline Eli Duttman  United States
If at all possible, mount the choke on the side wall. Doing so allows the coil of the choke to be perpendicular to the coils of the other magnetics. Take full advantage of all 3 spatial dimensions.
If the side wall is not available, mount the choke at 45o to both the power and O/P transformers.
Eli D.
Old 19th November 2013, 12:59 AM   #10
The choke is a hair larger than 3" and the chassis is only 3" deep. I can maybe figure out a way to mount it on the sidewall but it will be TIGHT. I really like the 45 degree idea and might have to go with that if I can't use the sidewall.
Monoblock projectHide this!Advertise here!
845 A2 Monoblock Project Bryan Tubes / Valves 299 10th December 2010 03:46 PM
