Circuit for testing tube/valve - Help! - diyAudio
Old 18th November 2013, 11:55 AM   #1
Gost22 is offline Gost22  Bolivia
Banned
Lightbulb Circuit for testing tube/valve - Help!
Hi all!
I need a schematic (circuit) for testing gain and characteristics of tube/valve 12AX7, 12AU7, ECC88 and others.
thank you!
Old 18th November 2013, 12:27 PM   #2
kevinkr's Avatar
Take a look at the uTracer, you can build this if ambitious or buy the kit. Here: The uTracer, a miniature Tube Tester / Curve Tracer.
Alternately you could make a simple jig to test transconductance using some simple power supplies and DMM.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 18th November 2013, 12:53 PM   #3
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Are you only interested in testing the specified dual triodes? Or are you interested in a more general tester?
If the former, take a look at this:
The Valve Wizard
Old 19th November 2013, 01:32 AM   #4
Banned
Thumbs up Testing the dual triodes.
The Valve Wizard
Only interested in testing the specified dual triodes.
Please tell us what needs to be tested in these dual triodes (ecc81; ecc82; ecc83; ecc88,... etc.) to determine whether they are good to use?
Whether this schematic is good for this use?
Thanks for your help!
P.S.
Does anyone know why that would not work Anage Attachments for me because I can not not get the schematic!?
Old 19th November 2013, 01:43 AM   #5
Banned
See The Valve Wizard.
Old 19th November 2013, 10:14 AM   #6
Banned
Lightbulb Schematic-1
Old 19th November 2013, 11:01 AM   #7
jazbo8's Avatar
This is one says "Do Not Build", try the one below it.
Old 19th November 2013, 11:05 AM   #8
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
If you struggle to understand English, here is a Spanish version of the web page:
Google Translate
Old 19th November 2013, 05:35 PM   #9
Location: Near Eindhoven, the sanctum of the pentode. and among that other things.
Send a message via Skype™ to v4lve lover
I suppose you take a look at the Sussex valve tester.
The "Sussex" Homebrew Valve Tester. - UK Vintage Radio Repair and Restoration Discussion Forum
A stripped down version of the unit would be just what you need, Anode current and transconductance.
The heaters would just be a 7805 whit two diodes from the gnd terminal to ground. this gives a solid 6.3V
Tube / Valve Mic Preamplifiers TubeTech Style Circuit S Keats Swap Meet 0 24th April 2012 08:23 PM
Valve testing machine Reeler Tubes / Valves 72 20th February 2012 08:09 AM
Valve Compressor Circuit wdcw Tubes / Valves 10 10th February 2011 04:43 AM
can't find valve art tube - and glowey tube pic wicked1 Tubes / Valves 23 10th February 2009 12:54 AM
Valve circuit in I, Robot Beelzebub Tubes / Valves 18 17th December 2004 04:36 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
