Teeny Tiny Spud - diyAudio
Old 18th November 2013, 03:10 AM   #1
wrenchone's Avatar
Default Teeny Tiny Spud
I have some Russian 6R4P double pentodes I bought on spec - they incorporate a very high transconductance ~5W video amp pentode and a smaller, lower transconductance ~2W pentode in one package. The rough equivalent is the ECF200. The only drawback I can see is that the base is a noval-ish 10-pinner rather than the usual 9 pin. Appropriate sockets can be still had on E-pay. At any rate, one use I can see for these things is a flea power partial feedback amp, either for headphone duty or driving tweeters. With the right transformers, it could be an ultra-mini amp.
Old 18th November 2013, 03:36 AM   #2
Do you have a decent data sheet? Is the socket the same as the double tetrode found in some H/K receivers? That item has a 10th pin at the center of what otherwise would be a routine Noval arrangement's pin circle.
Eli D.
Old 18th November 2013, 03:49 AM   #3
wrenchone's Avatar
The socket is the same as for the 6X9, with all the pins around the periphery. I've seen disjointed specs for the 6R4P which might suggest a higher power rating for the big, high conductance pentode, but if you want to be conservative, I'd use the specs for the ECF200, which can be had at the cost of a Google search. An Ebay search for "ECF200 socket" might lead you to Zhangsheng, who has some decent looking product...
Old 18th November 2013, 05:54 AM   #4
wrenchone's Avatar
Actually, it's the EFL200 that is the rough 6R4P equivalent - sorry for the wild goose chase.
Old 18th November 2013, 06:28 AM   #5
So there is a use for EFL200? Interesting that is
Old 18th November 2013, 09:06 AM   #6
wrenchone's Avatar
Another very similar tube is the 6Y9 (looks to be the same, really).
Novar Spud :: A $200 sweep tube Spud with PCB tomchr Tubes / Valves 94 22nd December 2016 05:41 AM
Tiny, tiny DC-DC converter jackinnj Power Supplies 1 28th June 2006 08:03 PM
any good tiny tiny tweeters? THOR Multi-Way 18 28th June 2004 07:42 AM
Teeny, Tiny, Microcontrolers. bigparsnip Digital Source 19 27th August 2003 02:44 PM
where to get teeny tiny drill bits? cowanrg Parts 20 2nd August 2003 07:54 PM
Copyright 1999-2017 diyAudio
