heaters connected to cathode?!
Old 16th November 2013, 10:30 PM   #11
lordearl is offline lordearl  Australia
Originally Posted by Magz View Post
Sounds like a directly coupled stage, with one half of the 6SN7 feeding the other, for increased gain. Rather low plate voltage for a 6SN7.
Brilliant! This has been driving me crazy. Is this a well known type of circuit? Any common schematics as examples? I think a re-wiring might be in order to fix the plate voltages.....
Old 17th November 2013, 02:46 AM   #12
Magz is offline Magz  United States
Yes, common. Often used in preamps to increase gain. Supratek Chenin preamps are an example, where they use a directly coupled 6SN7 as the gain stage.
heaters connected to cathode?!Hide this!Advertise here!
amplifier works connected to PC .. but not when connected to car radio anwaypasible Analog Line Level 1 2nd March 2011 07:42 PM
Triode connected Pentodes in a cathode bias? leadfootdriver Tubes / Valves 4 3rd September 2009 10:11 PM
300B Cathode Feedback + Cathode Bias korneluk Tubes / Valves 13 7th January 2009 08:07 PM
UL to triode mode conversion on cathode bias amp-different cathode resistors needed? bigwill Tubes / Valves 6 30th December 2007 12:37 AM
Referencing DC heaters to cathode cbutterworth Tubes / Valves 31 3rd October 2007 10:16 PM
