More questions on parallel push-pull
Old 15th November 2013, 10:38 PM   #11
Eli Duttman is online now Eli Duttman  United States
Have tried direct coupling with 6Bl7's gets very complicated with 4 tubes, Best to stick to two tubes. never tried it with Mosfets.
Perhaps I wasn't clear enough. DC couple enhancement mode MOSFETs to the tubed small signal circuitry and use individual caps. to connect the buffers to each of the O/P tube grids. If you run an IRFBC20 source follower with a drain current of 20 mA., expect the O/P impedance to be well under 100 ohms. Multiple smallish grid to ground resistances will not be a problem.
Eli D.
Old 15th November 2013, 11:20 PM   #12
mskl99 is offline mskl99  United States
Originally Posted by multi View Post
even made a 12 x 807.
Holy Cow, what primary impedance did you choose for that one?
Old 15th November 2013, 11:22 PM   #13
Matt BH is online now Matt BH  United Kingdom
Hey Eli, This exactly the way I built a multiple 6l6oid amp a while back. It used Tubelab's and Chrish's design. Seperate FETs for each tube, seperate bias pot each and seperate coupling cap to the previous long tail pairs anodes for each side. I used an anode choke in mine to get enough swing to drive the outputs in triode with my supply. I got 100W reliably from four 5b25x types in triode.
I would say that seperate bias is a must in push pull parallel output stages.
6L6GC AB2 Amp
Cheers
Matt.
Old 15th November 2013, 11:30 PM   #14
Sorry, I see you meant the other way round. Yes a good approach to drive the increased miller capacitance of multiple pairs. I think sand is cheap enough to use seperate FETs for each tube and enjoy DC coupling there.
Cheers
Matt.
Old 16th November 2013, 01:47 AM   #15
Cheers
Matt.
There are pluses and minuses to both approaches. IMO, the key thing is that FETs can be terrific "spear carriers" for tubes. Think heaterless pentode.
Eli D.
Old 16th November 2013, 07:22 AM   #16
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
a small PCB with multiple taps
sometimes we know very little, and sometimes we know too much
Old 16th November 2013, 11:56 AM   #17
Changed the commercial amps to separate caps and no more trouble.
good to know
sorry that I'm a bit confused (probably my english)
but direct coupling is not just like a walk in the park
are you really suggesting a DC coupled buffer for each tube ?
or I have misunderstood, and you meant 'just' one for each 'side', and still use multiple/seperate coupling cap to each tube
(and so basicly the mosfets buffers are mostly to ease the harder load/drive)
Old 16th November 2013, 07:55 PM   #18
stumbled over this old thread
may be worth a look
IRFBC20 as source follower drivers for EL34s in AB1 PP
still searching for that schematic
If you run an IRFBC20 source follower ...
ah, ok, got it ... like in tube 'cathode' buffer
configured like a differential tube driver
and a balanced preamp
sorry, I seem to be on my manic tube ride now
Old 16th November 2013, 10:03 PM   #19
he, found something ... balanced/symmetric cathode follower
but still no source follower mosfet in there
Old 16th November 2013, 10:22 PM   #20
DC coupling "N" channel enhancement mode MOSFET source followers to tube plates IS a walk in the park.
The phono preamp schematic I've uploaded illustrates how it's done. Obviously, the gate is at the same potential as the plate it's tied to. The source sets up a few V. below the gate, but it's OK to ignore that small differential. Select a rational drain current value and use Ohm's Law to compute the source load resistor.
Eli D.
More questions on parallel push-pullHide this!Advertise here!
KT88 Parallel Push Pull Xpersephone2 Tubes / Valves 67 16th September 2014 11:02 AM
Push-Pull vs Push-Pull-Parallel rsumperl Tubes / Valves 8 10th July 2012 06:34 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 4th November 2005 12:25 AM
Parallel Push Pull Drivers gingertube Tubes / Valves 14 13th May 2005 02:32 PM
parallel or push-pull vlljpior Tubes / Valves 1 6th December 2004 01:13 AM
