Push pull class A bias question - Page 2 - diyAudio
Old 21st December 2003, 10:42 AM   #11
Brett's Avatar
Originally posted by Jax
One 12AX7 and a pair of 6BQ5? Made me think for a while and came up with an idea using the old paraphase splitter.
Schematic
I like it. Similar to a 6V6 amp I built a while back.
Play with the imbalance and see if you like the sound; 5% seemed pretty nice. But ditch the 12AX7's and put in a decent sounding tube like an ECC99.
Old 21st December 2003, 10:59 AM   #12
Jax is offline Jax  Sweden
ECC99 would require some changes to my circuit though.
Change R2 and R3 to 22K 2W, R6 to 5.6K 2W, R16 and R17 to 680 ohm as a suggestion (100V Va at 5 mA).
Old 21st December 2003, 12:35 PM   #13
Brett's Avatar
I know.
Waaaaaaaaaaaaaay too low an op point; they don't really wake up until 15mA. I used choke and later CCS loading in mine.
Old 21st December 2003, 01:48 PM   #14
I agree
I just thought it was a bit hot there
Old 21st December 2003, 02:51 PM   #15
SY's Avatar
No, you don't need an extra cap...If the source is cap coupled, you don't want a second cap.
Frank, you really want DC running through that pot? The required second cap is not to isolate the source but to keep the biasing DC off the pot wiper. Moot, since this is now a design for a CDP, and the "phase splitter" will now need gain.
I still maintain that a simple diff amp is still the best choice here for this application. Gain, low parts count, stability, reasonable balance, and a convenient node for any desired loop feedback.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 21st December 2003, 04:20 PM   #16
Default Just breadboarding
to learn. Diff amp could be next attempt, Sy.
Tim- I do have about 100k as load to 12ax7 don't I? Makes no difference how many resistors or where they are in the series, no?
Changed R1 to 1k. Changed the input grounding, too. Lost the jumper.
Parts counts on this one is 2.5 tubes (2 6bq5 and 1/2 12ax7).
I should have 50v swing from driver, right? This would be split up to outputs?
Rick
Old 21st December 2003, 06:06 PM   #17
Correction: driver tube will swing from about 80 v to about 200v using 100k load resistor to be split between two output tubes. More than enough to drive the 6bq5s.
Old 21st December 2003, 11:32 PM   #18
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Erm... now you have a floating input. Put a 100k to 1M resistor between grid and the join between R1 and R2, put a capacitor between grid and input, and ground the ground side of input.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 22nd December 2003, 04:18 AM   #19
Default Thanks, Tim
Won't the 100k vol pot suffice instead of adding another grid resistor? Capacitor on the input? For CDP input, does the circuit need it? If I ground the ground side of input, won't that effectively put the grid input at -150v bias (below both the load resistor and the cathode bias resistor)?
Appreciate the comments,
Rick
Old 22nd December 2003, 06:49 AM   #20
Sch3mat1c's Avatar
No. The grid has to float on top of the cathode at its circa 75V potential.
Grounding the input will not put the grid at -150V vs. cathode because for one thing, cathode voltage will follow grid voltage naturally (and because of the nature of the circuit, plate voltage will be an inversion of this), so it wouldn't be a full 150V, and two, you use a capacitor so the grid bias is set by R1 instead.
Tim
Push-Pull Cathode Bias Resistors Kashmire Tubes / Valves 24 6th July 2016 07:14 AM
push pull bias servo xdissent Tubes / Valves 25 6th August 2013 08:35 PM
Bell 2420 tube amplifier. Bias question. 6v6 push pull The Donk! Tubes / Valves 5 30th May 2013 09:40 AM
EL84 Push-Pull ccs bias Tobruk Tubes / Valves 14 2nd May 2007 11:19 PM
Push pull dht triode with diode bias James D. Tubes / Valves 24 5th January 2003 08:19 AM
Copyright 1999-2017 diyAudio
