Twists per inch on filament wiring? - Page 2 - diyAudio
Old 22nd December 2003, 04:27 PM   #11
Default Re: The more the merrier
Originally posted by EC8010
As Sch3mat1c says, it's all about having the same capacitance from each heater wire to a given audio point. An infinite number of twists per inch would guarantee equal capacitances, and provided that the heater wiring was perfectly centre-tapped to earth, would produce zero hum. Since more twists per inch doesn't cost money, I use as many as I can. Solid core wire is much easier to twist tightly. Push it tight into the corners of the chassis, and bring it up to the valve at the last moment.
If capacitive coupling is inducing the hum, I'd suggest a screen, much easier to apply
Mostly it is inductive coupling
Ciao
Guido Tent
www.Tentlabs.com
Old 22nd December 2003, 05:15 PM   #12
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
It's both, but you don't need much of a twist to cancel the magnetic field. Screening heater wiring is possible, but tends to be fiddly. To keep this in perspective, the classic valve manufacturers managed to make RIAA pre-amplifiers with tolerable hum using AC on their heaters.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 22nd December 2003, 05:45 PM   #13
Hi EC8010,
The dominant coupling mechanism depends on both source and receiving impedance.
Perspective is correct, but to make it a little more quiet.....
Once had capacitive coupling from anodes of rectifier tube. Rotated that until coupling was balanced :-)
Guido Tent
www.Tentlabs.com
Filament wiring question Magnetmaz Tubes / Valves 26 18th September 2010 05:37 AM
Filament Wiring - Shielded vs. Twisted? k9swc Tubes / Valves 21 27th May 2009 07:12 PM
2 inch Peerless vs 2 inch HiVi Research richie00boy Multi-Way 18 5th December 2007 07:31 PM
Parallel vs. series filament supply - or another filament idea engels Tubes / Valves 11 13th May 2007 01:06 PM
Passive Radiator system with 2x10 inch and 1x15 inch Lach O'Sullivan Multi-Way 3 13th September 2003 03:29 PM
Copyright 1999-2017 diyAudio
