Twists per inch on filament wiring?
Old 20th December 2003, 04:28 PM   #1
G is offline G  United States
G's Avatar
Default Twists per inch on filament wiring?
Is there a recommended number of twists per inch on filament wiiring to prevent hum? Thanks.
Gavin
Old 20th December 2003, 05:28 PM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
A lot more twists are required to hold the wires together, than to hum cancel.
Have a look at the manufacturers twist in a network cable or balanced audio cable - maybe between 1 to 4 per inch! Doing more shouldn't hurt.
Don't forget that by placing the wires in thermal contact, the current rating of the wire is practically halved (for a given temperature rise).
Old 20th December 2003, 10:39 PM   #3
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
For optimum smoothness, it must be twisted exactly 162 crossings to the inch, using flat sheet type tantalum-plated silver-impregnated superconductors, wound edge-on. This assures maximum cancellation of the DC field (you're using DC heaters right? Anything else makes the sound stage ricketey as an 1860s theatre).
I could do better but I don't feel like taking the time right now...
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 20th December 2003, 11:23 PM   #4
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Weekends are just not his thing...Dunno why.
The other days of the week it's just an attitude almost as bad as mine...
DC fields...What's next?
Frank
Old 20th December 2003, 11:27 PM   #5
G's Avatar
No I'm using AC heaters and I was just curious. The sarcasm is not appreciated. I don't think that it is out of the realm of possibility that more or less twists per inch would have different levels of success at cancelling 60 cycle hum.
Gavin
Old 20th December 2003, 11:34 PM   #6
fdegrove's Avatar
It's not so much the number of twists that cancel the hum but I'll garantee you that it works just as it works for a twisted pair.
Just ignore the crackheads...
D'haen gave you what you need to know so go for it.
Frank
Old 21st December 2003, 03:48 AM   #7
Sch3mat1c's Avatar
Hey, that's mine and Mark's word for you...
Ok, fine, a serious answer: yes, the field should cancel quite nicely even for plain parallel runs. But the problem would then be, for instance, capacitance coupling to nearby wires which average being closer to one wire than the other: twisting balances this statistic. So just a few twists will work. Also the wire should be near the chassis, so that the field is mostly grounded away.
Frank, you sound like DC fields don't exist... what are magnets and electromagnets? Of course, they don't make any difference to non-moving wires, hence the sarcasticalism...
Tim
Old 21st December 2003, 04:29 AM   #8
fdegrove's Avatar
No, it's just that I read the threadstarter's question....
D.C. Fields? Yes, still playing with model trains are we?
And you did consider how that neologism was going to come across....
Frank
Old 22nd December 2003, 07:59 AM   #9
Guido Tent is offline Guido Tent  Netherlands
Default Re: Twists per inch on filament wiring?
I'd suggest to twist such that the wires cross at 90 degrees
regards
Guido Tent
www.Tentlabs.com
Old 22nd December 2003, 02:16 PM   #10
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Default The more the merrier
As Sch3mat1c says, it's all about having the same capacitance from each heater wire to a given audio point. An infinite number of twists per inch would guarantee equal capacitances, and provided that the heater wiring was perfectly centre-tapped to earth, would produce zero hum. Since more twists per inch doesn't cost money, I use as many as I can. Solid core wire is much easier to twist tightly. Push it tight into the corners of the chassis, and bring it up to the valve at the last moment.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Twists per inch on filament wiring?Hide this!Advertise here!
Filament wiring question Magnetmaz Tubes / Valves 26 18th September 2010 05:37 AM
Filament Wiring - Shielded vs. Twisted? k9swc Tubes / Valves 21 27th May 2009 07:12 PM
2 inch Peerless vs 2 inch HiVi Research richie00boy Multi-Way 18 5th December 2007 07:31 PM
Parallel vs. series filament supply - or another filament idea engels Tubes / Valves 11 13th May 2007 01:06 PM
Passive Radiator system with 2x10 inch and 1x15 inch Lach O'Sullivan Multi-Way 3 13th September 2003 03:29 PM
Copyright ©1999-2017 diyAudio
