Basically what happens is when i attach the 47k input resistor to pin 7 it gets a nasty buzz/humm through it. I start measuring about .120 of ac volts. Where on the other channel I measure .004 ac volts.
schematic here-( http://www.quadesl.com/pdf/sa100_photofacts.pdf )
Any ideas would be great. I have given it about 8 hours of trying and I cant figure it out. I will try anything.
What do you mean by "Anybody ever do the coupling caps on an amp....
Have you replaced caps and now find you have this problem where before you did not ?
Disclaimer... I don't normally do tooobs however caps, which are basically large areas of foil wrapped up in a can, act or can act as antennas. Were the original caps fitted in such a way that the "outer" of the foil was connected at the low impedance end of the cap location thus using the outer foil as shield. Or were they a construction that was immune to pickup.
I replaced the four .047 coupling caps and the .022 cap on the input. I only removed the bypassed 47k to try and trouble shoot it. It is back on there right now. I gave this a couple of days to sit and see I could come back to it with a fresh head and the solution would present itself. I usually just rebuild things from the ground up when I run into problems, because I don't know enough. I would like to avoid that and learn something about tube amps this time.
Blindly replacing components instead of fault-tracing is as likely to introduce new faults as fix old faults. As you have now found. Even when bulk replacement is appropriate, this should only be done a few components at a time with checks for correct operation between each set of changes. Then you know where you went wrong.
Something you did was wrong. You have to keep checking until you find it. Or hand it over to someone who can fault-trace - which will be difficult with so many changes.
Thanks for the lectureBlindly replacing components instead of fault-tracing is as likely to introduce new faults as fix old faults. As you have now found. Even when bulk replacement is appropriate, this should only be done a few components at a time with checks for correct operation between each set of changes. Then you know where you went wrong.
Thank you for being constructive. I know its nearly impossible to arm chair diagnose something like this. I could bring this to somebody to fix it, but it wouldn't be satisfying and I would miss the accomplishment of doing it myself. Not having any formal training in electronics, I have been taught everything I know by these forums. To the credit of folks around here I have had many success story's. Thanks for the good spirit.It might be helpful to take measurements with a DMM of the 'good' channel,and compare them to the 'bad' channel.
Sometimes it's hard to spot what you've goofed up,if indeed you did goof up. Some checks with an ohm meter might shed some light.
Well its been sometime since I checked in. That's because I can not make any progress with it. It was three lousy capacitors and its blowing my mind lol. I will try your wrapping technique. You would figure after moving in so many directions I would eventually move in the right one. Not yet.Another thing, I found some film and pio capacitors very susceptible to rf and similar junk pickup and ended up screening them, particularly russian pio caps. Wrapping them with copper foil and soldering a wire to the ground worked for me.
- Tubes / Valves
- radio like interference condition in SA-100
