radio like interference condition in SA-100
Old 1st November 2013, 04:14 AM   #1
jasondace2b is offline jasondace2b  United States
Default radio like interference condition in SA-100
Anybody ever do the coupling caps on an amp and then wind up with radio like interference where something is acting like an antenna on the input tube side? Or does anybody no of this condition and how it occurs?
Old 2nd November 2013, 02:12 PM   #2
Basically what happens is when i attach the 47k input resistor to pin 7 it gets a nasty buzz/humm through it. I start measuring about .120 of ac volts. Where on the other channel I measure .004 ac volts.
schematic here-( http://www.quadesl.com/pdf/sa100_photofacts.pdf )
Any ideas would be great. I have given it about 8 hours of trying and I cant figure it out. I will try anything.
Old 2nd November 2013, 02:21 PM   #3
Mooly's Avatar
What do you mean by "Anybody ever do the coupling caps on an amp....
Have you replaced caps and now find you have this problem where before you did not ?
Disclaimer... I don't normally do tooobs however caps, which are basically large areas of foil wrapped up in a can, act or can act as antennas. Were the original caps fitted in such a way that the "outer" of the foil was connected at the low impedance end of the cap location thus using the outer foil as shield. Or were they a construction that was immune to pickup.
Old 2nd November 2013, 08:51 PM   #4
Yes that is exactly what happened but it only happened on one channel. I double and triple checked making sure nothing was touching something it shouldnt be. As far as the new capacitors they are orange drops and i never had a problem before. hmmmm
Old 3rd November 2013, 02:27 AM   #5
gootee is offline gootee  United States
Which caps did you replace, exactly? And why did you have the 47k disconnected if you were replacing caps?
The electrolytic capacitors ARE the signal path: http://www.fullnet.com/~tomg/zoom3a_33kuF.jpg
Old 3rd November 2013, 11:12 AM   #6
I replaced the four .047 coupling caps and the .022 cap on the input. I only removed the bypassed 47k to try and trouble shoot it. It is back on there right now. I gave this a couple of days to sit and see I could come back to it with a fresh head and the solution would present itself. I usually just rebuild things from the ground up when I run into problems, because I don't know enough. I would like to avoid that and learn something about tube amps this time.
Old 3rd November 2013, 08:52 PM   #7
DF96 is offline DF96  England
Blindly replacing components instead of fault-tracing is as likely to introduce new faults as fix old faults. As you have now found. Even when bulk replacement is appropriate, this should only be done a few components at a time with checks for correct operation between each set of changes. Then you know where you went wrong.
Something you did was wrong. You have to keep checking until you find it. Or hand it over to someone who can fault-trace - which will be difficult with so many changes.
Old 3rd November 2013, 10:17 PM   #8
Thanks for the lecture
Old 3rd November 2013, 10:59 PM   #9
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
It might be helpful to take measurements with a DMM of the 'good' channel,and compare them to the 'bad' channel.
Sometimes it's hard to spot what you've goofed up,if indeed you did goof up. Some checks with an ohm meter might shed some light.
Old 3rd November 2013, 11:28 PM   #10
Thank you for being constructive. I know its nearly impossible to arm chair diagnose something like this. I could bring this to somebody to fix it, but it wouldn't be satisfying and I would miss the accomplishment of doing it myself. Not having any formal training in electronics, I have been taught everything I know by these forums. To the credit of folks around here I have had many success story's. Thanks for the good spirit.
radio like interference condition in SA-100Hide this!Advertise here!
counterpoint sa-100/sa-220 schematics? Williams Audio Solid State 15 12th June 2017 08:45 PM
Class D/T and radio interference? Moejoe Class D 2 3rd May 2013 01:02 PM
Radio Interference ElecronicsEdC Chip Amps 3 21st April 2011 07:37 PM
Radio frequency interference kgb_m3 Chip Amps 39 1st February 2010 09:54 PM
counterpoint sa-100/sa-220 schematics? Williams Audio Analog Line Level 3 24th February 2006 05:46 PM
Copyright ©1999-2017 diyAudio
