Tube powered subwoofer - diyAudio
Old 1st November 2013, 02:42 AM   #1
Default Tube powered subwoofer
I have recently acquired a dead Pioneer subwoofer and had the great idea of building a tube powered subwoofer using the enclosure and speaker.
Does anybody have a schematic I could use?
Old 1st November 2013, 03:09 AM   #2
vinylkid58's Avatar
The amp will need to be in it's own enclosure/chassis, not attached to the sub box. The vibration would be a killer.
jeff
Old 1st November 2013, 03:12 AM   #3
Talk to any of the custom "iron" builders. Optimizing an O/P transformer for high power and low frequencies only is not particularly difficult.
"Fixed" bias PPP KT88s in either a Williamson or Mullard style circuit will get the job done. Definitely SS rectify the B+. Antek's AS-4T360 should take care of all power requirements, except the small signal tube heaters. You could go DC there and knock the residual hum level for a loop.
Have you given any thought to crossover requirements?
Eli D.
Old 1st November 2013, 01:40 PM   #4
Tom Bavis's Avatar
How much power are you looking for? I have a 6.6K 50W transformer that measured 750 Henries on the primary at 10V/20 Hz...
Old 1st November 2013, 04:12 PM   #5
45 is offline 45  Italy
45's Avatar
jeff
It is so logical....
JBL Powered SubWoofer - Need Schematic poynton Subwoofers 7 6th March 2010 12:49 AM
how to connect a non powered subwoofer to a stereo system without a subwoofer output JSD777 Multi-Way 4 20th September 2005 04:19 PM
where to buy powered subwoofer? secateurs Subwoofers 4 11th July 2005 09:59 PM
need help repairing powered subwoofer mbates14 Solid State 12 10th June 2005 12:30 AM
Help in transforming a powered subwoofer in a passive one!!! Rimbaldo Subwoofers 5 19th June 2004 06:26 PM
Copyright 1999-2017 diyAudio
