Power supply question:twin choke input? - diyAudio
Old 31st October 2013, 01:10 PM   #1
gtrmkr is offline gtrmkr  United States
Default Power supply question:twin choke input?
Hello,
I was scrounging through my junk box yesterday looking for power supply parts and, not finding chokes with a high enough current rating for my intended application, got to wondering ...
I know that placing a choke in both the positive and negative legs in a full-wave bridge, cap input supply works.
Will it work with a full-wave, choke input arrangement?
In either case, how is the load current distributed between the two chokes?
I've attached a crude schematic of the latter case for reference.
Thanks very much!
Old 31st October 2013, 04:10 PM   #2
DF96 is offline DF96  England
Each choke carries the full load current, but only half the AC voltage swing. OK for chokes which are beefy enough for the current but can't cope with the voltage. The opposite of what you need?
Old 31st October 2013, 04:26 PM   #3
Thanks. That's what I suspected, and yes, opposite of what I need.
I did find a swinging choke with a current rating large enough (2H-12H @ 300ma) but am unsure if it's appropriate to use for a choke input, class A circuit. I think not ... correct?
Old 31st October 2013, 04:54 PM   #4
rongon is offline rongon  United States
rongon's Avatar
Shouldn't it be possible to parallel a pair of chokes to get half the value in Henries, but at twice the current capacity?
For example, if I had two 7H 150mA (140 ohms DCR) chokes, and I wire the pair of them in parallel, wouldn't that work the same as a single 3.5H 300mA (70 ohms DCR) choke?
Old 31st October 2013, 05:39 PM   #5
Both chokes are from the same manufacturer and within a couple Ohms DCR, so that should work fine, and what I will likely wind up doing. Thanks for the suggestion.
Is there a reasonably simple way to guesstimate the inductance of a swinging choke at a particular current?
Thanks again. I really appreciate the info.
Old 31st October 2013, 06:41 PM   #6
Swinging chokes are commonly used for choke input supplies. Your best bet is to rig it up and measure it e.g. see how output voltage varies with load.
Old 1st November 2013, 09:25 PM   #7
Thanks. Will do ... My weekend project!
Old 2nd November 2013, 08:52 AM   #8
Vinylsavor's Avatar
Hi!
Yes you can do that
Thomas
http://vinylsavor.blogspot.com/
Old 2nd November 2013, 08:54 AM   #9
Vinylsavor's Avatar
Hi!
Yes, swinging chokes are meant for choke input duty. I don't have much experience with swinging chokes. As far as I understand they might be mechanically noisy (buzzing) since they are driven into saturation.
You can try and see if they work for you
Thomas
Choke input supply. Cap question. deicide67 Tubes / Valves 16 15th August 2013 07:16 PM
choke input power supply filter audionut Pass Labs 55 20th May 2013 08:17 PM
choke input power supply vitalstates Tubes / Valves 10 24th February 2012 01:03 PM
Choke input power supply, capacitor ratings 00940 Tubes / Valves 14 7th July 2009 05:52 PM
Choke input Power Supply NickC Solid State 4 6th November 2002 07:41 PM
Copyright 1999-2017 diyAudio
