Transformers Specs for a 2x KT88 Amp - Page 3 - diyAudio
Old 17th November 2013, 04:04 PM   #21
jazbo8's Avatar
One of many possibilities:
Old 17th November 2013, 09:23 PM   #22
The load line shown is not an AC load line which will be an elipse, not a line. So long as more of the elipse area falls below the dotted 33W limt than above then you are fine, that is, so long as the average power is below your (self imposed) 33W limit.
Ian
Old 19th November 2013, 08:00 AM   #23
Yes, that looks more like it. Interesting to realise that there is very small difference in output power between 300 and 250 Volts screen. It is because we are allowed to hit the knee part of the curves.
For sure a resistive load is anything but realistic, just a starting point that makes sure it will work more or less.
what range speaker used 2x 18watt or 2x 10 watt on 18 watts amp plig88 Instruments and Amps 10 22nd February 2013 06:37 PM
Summing (2x) opposite-phase signals with Transformers ryansupak Analog Line Level 0 4th August 2012 02:14 AM
FS 2X Atma-Sphere transformers Zero Cool Swap Meet 3 23rd October 2011 03:53 AM
FS: 2x UCD700HG+HxR, 2x UCD700 PS, transformers, accessories. TrNSZ Swap Meet 0 28th April 2011 02:10 AM
WTB: 2x Hypex UCD180 amp modules and 2x SMPS power supplies jdubs Swap Meet 0 22nd April 2010 01:10 AM
Copyright 1999-2017 diyAudio
