Old 12th August 2011, 10:54 PM   #281
pre65 is offline pre65  United Kingdom
I have a pair of 833a monoblocks. Currently undergoing mods to take them to mk3 version.
Old 13th August 2011, 12:08 AM   #282
rcavictim's Avatar
I can feel the radiant heat from here across the pond! Safety aspects aside, that's definitely a fun project! How high is your killer B+ ?
I.Q.Test. Have you ever purchased a recreational snowmobile?
Old 13th August 2011, 06:01 AM   #283
Actually, it's not that high.
I was advised that 1,000V was minimum for good results, but with the PSU bits I had to hand iv'e "only" managed about 950V HT
First version used my 300b SET amp via a 5K output transformer on the 16R tap to drive the 833a grid, sounded very nice. Version 1A used a small interstage transformer at about 1 :4.5 ratio, but that was less successful.
Current version (mk 2) uses a 6SN7 and EL34 (as cathode follower with fixed negative bias) to drive 833a.
Next version will give a negative supply to the EL34 cathode to correct a slight anomaly on the waveform that the scope found.
Philip Ramsey (Bluebell Audio) is trying to get Hammond to make some special interstage ( about 6:1 from memory) driving transformers, as he thinks that is the best way. I'm sure going to want to try them when (or if) they become available.
Old 9th February 2012, 11:43 PM   #284
Default SRPP-833
I don't think this circuit going to work, but I am going to post here and asking for your input.
I want drivers and output tube use the same DC supply. Keep power supply simple
Thanks, 101Audio
Old 26th December 2012, 04:05 PM   #285
Send a message via MSN to Peter 807
Smile High power Amp
Why nog make an 4CX250b SE -Amp,about 65Watts and 1000-2000 V ,Anode,grids stabilized.
Big Supply transformator end Big SE trafo.
Used an ECC83,and an EF183 for drive.
Searcing for trafo will be difficult,but fun.
Also PP is possible Output would be around 200Watts,8Ohm use an 4 Ohm tap,to drive the 8Ohm will make an very stable Amplifier,with around 85Watts.
For more info please contact me.
For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! opc Swap Meet 23 2nd November 2009 05:04 PM
Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest mbcouple Swap Meet 2 27th October 2008 10:27 PM
SMPS for diy audio amps and multi-channel diy amps (and their power supplies) tlparker Solid State 18 31st August 2006 10:39 AM
Why do some Bogan amps sound so good as guitar amps? amperex Instruments and Amps 7 22nd June 2006 11:46 AM
Has anyone compared GC amps(LM3875/3886/4780) with other DIY SS amps(Leach,ESP) ? percy Chip Amps 31 13th January 2006 01:33 AM
Copyright ©1999-2013 diyAudio
