Vacuum Tube SPICE Models
Old 17th August 2015, 06:23 AM   #971
jazbo8 is offline jazbo8
jazbo8's Avatar
I the tube symbols are missing in your LTSpice since euro21 already included the models in his zip file. If so, please unzip the attached file into the LTC\LTSpiceIV\lib\sym\Misc sub-directory and re-start LTSpice again.
https://dl.dropboxusercontent.com/u/1326040/tubesym.zip
Old 17th August 2015, 07:57 AM   #972
euro21 is offline euro21  Hungary
Originally Posted by Flipmoore View Post
how do you add the files to ltspice?
Simple create directory (for example 'Misc' ) under ...\lib\sym directory, and copy here *.sym symbols.
For example potentiometer.asy (which is editable simple text file, with .asy extension):
Version 4
SymbolType CELL
LINE Normal 16 88 16 96
LINE Normal 0 80 16 88
LINE Normal 32 64 0 80
LINE Normal 0 48 32 64
LINE Normal 32 32 0 48
LINE Normal 16 0 16 8
LINE Normal 16 8 0 16
LINE Normal -24 61 -24 35
LINE Normal -24 35 0 48
LINE Normal -24 61 0 48
LINE Normal -48 48 -24 48
LINE Normal 0 16 32 32
CIRCLE Normal -3 101 -11 90
WINDOW 0 33 0 Left 0
WINDOW 38 34 78 Left 0
WINDOW 39 33 107 Left 0
SYMATTR SpiceModel potentiometer
SYMATTR SpiceLine WiperPos=0.5
SYMATTR Prefix X
SYMATTR Description A potentiometer
SYMATTR ModelFile potentiometer.lib
PIN 16 0 NONE 0
PINATTR PinName A
PINATTR SpiceOrder 1
PIN -48 48 NONE 8
PINATTR PinName B
PINATTR SpiceOrder 2
PIN 16 96 NONE 0
PINATTR PinName C
PINATTR SpiceOrder 3
This symbol file refers to 'potentiometer', which is located in "potentiometer.lib" file.
If you use many own (created) symbols (as I) I recommend create own directories (in my case 'myLib') under ...\lib\sym, which contains symbol files, and the other (for example 'myLib') which contains *.lib files.
Old 19th August 2015, 04:06 AM   #973
Flipmoore is offline Flipmoore  United States
When attempt to run the I get an unknown subcurcuit error called in:xu8 +240v n003 n006 12ax_7
Old 19th August 2015, 06:26 AM   #974
jazbo8's Avatar
To Flipmoore:
Please help to keep this thread on topic.
It appears that you are having problems using LTSpice, so this thread isn't really the best place for posting your questions, could you please ask the Moderators (by clicking the little triangle on the lower left corner of your post) to move posts 956-973 to its own thread, someone should be able to help you with the problem. Thanks for your cooperation.
Old 22nd August 2015, 03:13 PM   #975
Alastair E is offline Alastair E  Wales
Alastair E's Avatar
Personally--I think it is EXACTLY the place to show issues adding models to LT. Keeps all LT stuff (AND the Problems/Solutions) together.
I cant get Anything at all to add to my current version of LT.
Just says when unzipped--Unable to extract to LT blahblah, Please check and try again.....
Das Beste Oder Nichts
Old 22nd August 2015, 04:02 PM   #976
jazbo8's Avatar
I beg to differ, please bear in mind that not everyone uses LTSpice, nor is this thread intended for LTSpice beginner tutorials, espically since there is already a very good one by Mooly on the Software & Tools Forum.
Old 30th August 2015, 10:08 AM   #977
bea is offline bea  Germany
Originally Posted by ingenieus View Post
Great thread, guys. I just read the whole thing and look forward to trying out the models that I have found.
In the spirit of giving back, here is a zip file with all the models in the thread. They are all in LTspice format (although I may have overlooked something along the way). Each model is in its own file. Just extract it to the directory c:\Program Files\LTC\LTspiceIV\lib\sub (or ~/.wine/drive_c/Program Files/LTC/LTspiceIV/lib/sub for the Linuxheads like me, hehehe) and have fun.
That's nice, thank You. Is it possible to merge them into a library which can be better maintained, i.e. a single file?
I would like to avoid clobbering my sub-Folder too much, and be able to switch between different tube libs...
As i am unexperienced with LTSpice - would it be sufficient to "cat" them into one single file, give that the extension .lib and install that?
Old 30th August 2015, 06:32 PM   #978
jazbo8's Avatar
Please use Installing and using LTspice. From beginner to advanced thread for all LTSpice related questions.
Old 13th September 2015, 04:46 PM   #979
jez is offline jez  United Kingdom
There are so many versions of models for common valves that it gets rather difficult to know which are the most accurate and suitable.
Could any of the spice experts on here suggest the most accurate models, which are suitable for multisim, for 12AX7, 12AU7, 12AT7, ECC88/6DJ8 and other such everyday use valves.
The Ayumi models seem very well regarded but don't run on multisim. I recall seeing a thread somewhere in which someone claimed to have converted all the Ayumi models for use with multisim but then declined to publish them in case it was "treading on the toes" of Ayumi himself....
Old 13th September 2015, 05:44 PM   #980
jazbo8's Avatar
For the tubes that you listed, any of the commonly available models will work.
Vacuum Tube SPICE ModelsHide this!Advertise here!
Vacuum tubes SPICE models, another way Dominique_free Software Tools 2 12th November 2013 06:26 PM
Tube spice models nhuwar Tubes / Valves 45 25th November 2011 08:47 AM
Computer program for tube curves and Spice models Jim Tonne Software Tools 9 21st November 2010 10:10 AM
Got my tube spice models, and tubed CD player page back on the air wa2ise Tubes / Valves 2 20th April 2008 11:07 PM
