Vacuum Tube SPICE Models
Old 1st December 2014, 11:23 PM   #601
RajkoM is offline RajkoM  Bosnia and Herzegovina
RajkoM's Avatar
...second data should be:
105V / -1,8V / 20mA
my typo, sorry.
Old 2nd December 2014, 05:26 AM   #602
jazbo8 is offline jazbo8
jazbo8's Avatar
Originally Posted by RajkoM View Post
Proposed 6P9P model is good for me. Quick check tells:
230V/-6V/44mA, and
145V/-1,8V/20mA.
Jazbo, typo is in "info part" of first line. Should be ..... P K G2 G.
But this typo does not affect the directive.
I must have changed the symbol names by mistake, because the model did not work for me as is... let me check it out and get back to you.
Old 2nd December 2014, 05:57 AM   #603
artosalo is offline artosalo  Finland
artosalo's Avatar
Proposed 6P9P model is good for me...
Could you share that 6P9P model ?
Old 2nd December 2014, 07:21 AM   #604
jazbo8's Avatar
105V / -1,8V / 20mA
my typo, sorry.
Could you please upload the complete .ASC and .SYM files for the 6P9 test circuit, I had to re-install LTSpice and lost all my old files...
Old 2nd December 2014, 08:51 AM   #605
jazbo8's Avatar
Originally Posted by artosalo View Post
Yes, thanks again. This seems to be the triode model of the pentode only, but the pentode side seems to be very similar to 6GV8 and this model I already have.
You can also try the ECL85P model from the Ayumi library, it should be pretty close to the 6F5P.
Old 2nd December 2014, 11:23 AM   #606
RajkoM's Avatar
This is a circuit where I quickly tested model from post 592.
Symbol model is tetrode model from Misc folder and LT spice.
Old 2nd December 2014, 01:43 PM   #607
jazbo8's Avatar
Thanks, I finally got the model to work but I am getting the same results as artosalo... Did you use the same curve data as shown in the picture below?
1. Ua = 102 V, Ug1 = 0 : Ia = 40 mA
2. Ua = 171 V, Ug1 = -3 : Ia = 38 mA
3. Ua = 242 V, Ug1 = -6 : Ia = 38 mA
So my results show too low anode currents.
6P9 Triode-Connected vs. the datasheet:
Old 2nd December 2014, 03:18 PM   #608
RajkoM's Avatar
Yes. I just checked.
Old 3rd December 2014, 09:21 AM   #609
nl3prc is offline nl3prc  Netherlands
nl3prc's Avatar
Originally Posted by jazbo8 View Post
The model i downloaded is not workin with my tetrode.asy looks like some pins are switched around
Old 3rd December 2014, 09:35 AM   #610
jazbo8's Avatar
Ayumi models always assign the pin numbers from the top to the botton of the tube, e.g., GU50PP A S G K. So just make sure whichever symbol that you use, assigns the pins in the same order. But this particular model was originally intended for TINA, so I don't think it would work in LTSpice at all... try this one instead:
Code:
* Generic pentode model: GU50_AN
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Sat Jan 11 08:13:44 2014
*               Plate
*               | Screen Grid
*               | |  Control Grid
*               | |  |  Cathode
.SUBCKT GU50_AN A G2 G1 K
BGG   GG   0 V=V(G1,K)+0.45288699
BM1   M1   0 V=(0.10715305*(URAMP(V(G2,K))+1e-10))^-1.1401545
BM2   M2   0 V=(0.56814856*(URAMP(V(GG)+URAMP(V(G2,K))/4.0302301)))^2.6401545
BP    P    0 V=0.0015719333*(URAMP(V(GG)+URAMP(V(G2,K))/7.0936201))^1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.0011497682*V(M1)*V(M2)
BIG   IG   0 V=0.00078596663*URAMP(V(G1,K))^1.5*(URAMP(V(G1,K))/(URAMP(V(A,K))+URAMP(V(G1,K)))*1.2+0.4)
BIK2  IK2  0 V=V(IK,IG)*(1-0.4*(EXP(-URAMP(V(A,K))/URAMP(V(G2,K))*15)-EXP(-15)))
BIG2T IG2T 0 V=V(IK2)*(0.916000233*(1-URAMP(V(A,K))/(URAMP(V(A,K))+10))^1.5+0.083999767)
BIK3  IK3  0 V=V(IK2)*(URAMP(V(A,K))+2101.25)/(URAMP(V(G2,K))+2101.25)
BIK4  IK4  0 V=V(IK3)-URAMP(V(IK3)-(0.0011298169*(URAMP(V(A,K))+URAMP(URAMP(V(G2,K))-URAMP(V(A,K))))^1.5))
BIP   IP   0 V=URAMP(V(IK4,IG2T)-URAMP(V(IK4,IG2T)-(0.0011298169*URAMP(V(A,K))^1.5)))
BIAK  A    K I=V(IP)+1e-10*V(A,K)
BIG2  G2   K I=URAMP(V(IK4,IP))
BIGK  G1   K I=V(IG)
* CAPS
CGA   G1  A  0.1p
CGK   G1  K  8.4p
C12   G1  G2 5.6p
CAK   A   K  9.2p
.ENDS
Vacuum Tube SPICE ModelsHide this!Advertise here!
Vacuum tubes SPICE models, another way Dominique_free Software Tools 2 12th November 2013 06:26 PM
Tube spice models nhuwar Tubes / Valves 45 25th November 2011 08:47 AM
Computer program for tube curves and Spice models Jim Tonne Software Tools 9 21st November 2010 10:10 AM
Got my tube spice models, and tubed CD player page back on the air wa2ise Tubes / Valves 2 20th April 2008 11:07 PM
