Vacuum Tube SPICE Models
Old 4th July 2014, 02:28 PM   #491
jazbo8 is offline jazbo8
jazbo8's Avatar
Originally Posted by nl3prc View Post
When i use the *.asy models and convert the .SUBCKT text to a file or drective he is using something like this
KALL LP1 LS1 LS2 LP2 LA1 LA2 LA3 0,998434750532354
Here you zie at the end that for the decimal he uses a , ( comma ) but this should be a . ( point )
Maybe this is a program fault becouse my windows is set on dutch
Yes, I believe this is the case, you can of course change the default European "," decimal point to "." in Excel.
Old 4th July 2014, 06:41 PM   #492
nl3prc is offline nl3prc  Netherlands
nl3prc's Avatar
I changed it in options of Excel now it gives . in stead of ,
Old 7th July 2014, 05:51 PM   #493
jackinnj is offline jackinnj  United States
jackinnj's Avatar
OK, it's not a vacuum tube -- perhaps we can convince the folks at PEAK to allow use of their GUI -- this is a curve of the LU1014 Power JFET, gm is about 80mS
Old 8th July 2014, 08:12 AM   #494
padamiecki is offline padamiecki  Poland
Hi
this is try of simulation EL34 amp, very good quality, indeed.
Attached asc file for play with (based on a file with EL12 amp).
Similar local nfb I used in one of my amps with succes.
Here to see more on inverters CCS Amplifier & Aikido Active Long-Tail Phase Splitters ,
cheers
regards, Pawel
Old 8th July 2014, 09:43 AM   #495
nl3prc's Avatar
Why do you feed the 12ax7 with the anode line of the 6ca7 this should be better this can give to mutch feed back.
And next time you post a ASC files also iclude the the lib or inc files
Old 8th July 2014, 10:08 AM   #496
=nl3prc;3984474]Why do you feed the 12ax7 with the anode line of the 6ca7 this should be better this can give to mutch feed back.
my target was full power at ~2Vpp input, like from most cd playres, or other sources,
besides it is not too much nfb untill the device not oscillates
this configuration gives euphinic sound end extraordinary deep of the soundstage.
this is link for real built amp: http://www.diyaudio.com/forums/tubes...tml#post898445
they were from your post Vacuum Tube SPICE Models
regards, Pawel
Old 8th July 2014, 10:43 AM   #497
nl3prc's Avatar
Missing files are dmtriodep.inc and cordell-models.txt those files i newer used in my sim
Old 8th July 2014, 11:04 AM   #498
please find attached
regards, Pawel
Old 8th July 2014, 11:26 AM   #499
nl3prc's Avatar
I see that those files are not realy used bij the sim so why do you have them as Included in the sim???
And why simulate on 20000 Hertz these freq is usaly not the problem 30 Hertz or lower is.
Old 8th July 2014, 11:29 AM   #500
I have standard directives for the simulations and I copied them for simulations, yes cordell-models.txt is not necessary.
20kHz is for the same reasons, you can easy change it to any frequency you want.
30Hz sim is not bad too.
regards, Pawel
Vacuum Tube SPICE ModelsHide this!Advertise here!
Tube spice models nhuwar Tubes / Valves 45 25th November 2011 08:47 AM
Computer program for tube curves and Spice models Jim Tonne Software Tools 9 21st November 2010 10:10 AM
Spice models stinius Solid State 0 18th November 2008 09:07 PM
Got my tube spice models, and tubed CD player page back on the air wa2ise Tubes / Valves 2 20th April 2008 11:07 PM
