Vacuum Tube SPICE Models
Old 1st July 2014, 01:59 PM   #481
jazbo8 is offline jazbo8
jazbo8's Avatar
Originally Posted by Almeida100 View Post
This is te link to a 4E27 triode-strapped SPICE: http://ja1cty.servehttp.com/4E27/spice.zip
Unfortunately, I am not sure how JA2DHC's triode curves were derived, but I was not able to use his triode data to create an usable pentode model, the result was way off from the datasheet.
Old 2nd July 2014, 02:15 PM   #482
nl3prc is offline nl3prc  Netherlands
nl3prc's Avatar
I also found a zipje with some output transformers.
Old 3rd July 2014, 06:33 AM   #483
jazbo8's Avatar
The attached ZIP file from Yahoo Groups only contain generic transformers, you still need to fill in the actual component values (LRC), a much more useful library is provided by Mr. McLean on this thread.
Old 3rd July 2014, 11:21 AM   #484
nl3prc's Avatar
My zip contains *.ASY files but also a transformer.CIR with that what you need to simulate
I try to open the file you referd to but it is in xls how doe im missing the ASY files
Old 3rd July 2014, 01:13 PM   #485
jazbo8's Avatar
Not sure if Mr. McLean provided instructions for his worksheet, but IIRC, on the upper left corner, you select the transformer number, and the code is automatically generated below, which then can be cut, paste and saved as the SPICE file (or pasted directly into the LTSpice ASC schematic).
Old 4th July 2014, 11:56 AM   #486
nl3prc's Avatar
Whatever instructions he provides the are blury
I know this the ones that i put in a zip is working.
Old 4th July 2014, 12:20 PM   #487
nl3prc's Avatar
I found the *.ASY files and i got it to work
With some changes in the XLS file he used for a decimal a , this should be a . ( point )
Old 4th July 2014, 02:05 PM   #488
jazbo8's Avatar
Finally had a chance to take a look at Mr. McLean's worksheet, the first tab contains very detailed instructions on how to use the worksheet to generate the models. And on each of the tabs, there is a corresponding image that's needed for the SPICE model - you need to make these symbols yourself unless you can find them on the net, or modify existing transformer symbols that you may have to match up the pin names.
Old 4th July 2014, 02:09 PM   #489
Ray Waters is offline Ray Waters  United States
I've used Robert McLean's spreadsheet before and haven't had a problem. Can you point out where in the spreadsheet you found the error?
Old 4th July 2014, 02:16 PM   #490
nl3prc's Avatar
When i use the *.asy models and convert the .SUBCKT text to a file or drective he is using something like this
KALL LP1 LS1 LS2 LP2 LA1 LA2 LA3 0,998434750532354
Here you zie at the end that for the decimal he uses a , ( comma ) but this should be a . ( point )
Maybe this is a program fault becouse my windows is set on dutch
Vacuum Tube SPICE ModelsHide this!Advertise here!
Vacuum tubes SPICE models, another way Dominique_free Software Tools 2 12th November 2013 06:26 PM
Tube spice models nhuwar Tubes / Valves 45 25th November 2011 08:47 AM
Computer program for tube curves and Spice models Jim Tonne Software Tools 9 21st November 2010 10:10 AM
Got my tube spice models, and tubed CD player page back on the air wa2ise Tubes / Valves 2 20th April 2008 11:07 PM
