Vacuum Tube SPICE Models
Old 21st March 2014, 04:30 PM   #401
jazbo8 is offline jazbo8
jazbo8's Avatar
Originally Posted by Ray Waters View Post
Your model is for the ECC33. I didn't think this was equivalent to the ECC88 (6DJ8/6922).
Ooops, corrected above.
Old 25th March 2014, 10:58 PM   #402
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Default WE437A?
A spice model compatible with Tina would be nice for this tube. Thanks.
I guess it's the same as the 6S45P?
Old 25th March 2014, 11:42 PM   #403
needtubes is offline needtubes  United States
Very similar... 6C45 has slightly higher plate dissipation (7.8W), slightly higher gain (~52), but lower maximum plate voltage (150V).
Old 25th March 2014, 11:46 PM   #404
dirkwright's Avatar
OK, thanks.
On another tube, I'm having real difficulty finding a tetrode model of a D3A. Can someone direct me to a link or something? thanks.
Old 26th March 2014, 03:48 AM   #405
cogsncogs is offline cogsncogs  United States
cogsncogs's Avatar
Originally Posted by dirkwright View Post
OK, thanks.
I have these two.
Code:
*           Plate
*           | Screen Grid
*           | | Grid
*           | | | Cathode
.SUBCKT D3a A S G K ; old model
Eat    at    0    VALUE={.636*ATAN(V(A,K)/20)}                    ; /# is sharpness of knee
Egsg    gsg    0    VALUE={LIMIT(V(S,K)/1+PWRS(V(G,K),1)/.0146+V(A,K)/80000,0,1E6)}    ; s,k/#=peak current  g,k/# is mu  a,k/# is plate res
Egss    gss    0    VALUE={LIMIT(V(S,K)/10000000000+PWRS(V(G,K),1.0)/.03+V(A,K)/80,0,1E6)}    ; separating gsg,gss allows cutoff to be different
Egs2    gs2    0    VALUE={PWRS(V(gsg),1.45)}
Egs3    gs3    0    VALUE={PWRS(V(gss),1.45)}
Ecath     cc        0     VALUE={V(gs2)*V(at)+V(gs3)*V(at)}
Ga         A         K         VALUE={5.4E-5*V(cc)}
Escrn    sc    0    VALUE={V(gs2)*(1.1-V(at))}
Gs         S         K    VALUE={5.0E-5*V(sc)*LIMIT(V(S,K),0,10)/10}
Gg    G    K    VALUE={PWR(LIMIT(V(G,K)+1,0,1E6),1.5)*(1.25-V(at))*450E-6}
Cg1    G    K    8.5p
Cak    A    K    6.5p
Cg1a    G    A    1.1p
.ENDS D3a
Code:
*                Plate
*                | Screen Grid
*                | | Grid
*                | | | Cathode
.SUBCKT 7721/D3a A S G K
Ea Gi G value= {-.09} ; grid offset
Eat    at    0    VALUE={.636*ATAN(V(A,K)/15)}                    ; /# is sharpness of knee
Egsg    gsg    0    VALUE={LIMIT(V(S,K)/1+PWRS(V(G,K),1)/.014+V(A,K)/80000,0,1E6)}    ; s,k/#=peak current  g,k/# is mu  a,k/# is plate res mu was too low
Egs2    gs2    0    VALUE={PWRS(V(gsg),1.4)}
Egs3    gs3    0    VALUE={PWRS(V(gss),1.4)}
Ga         A         K   VALUE={limit(6.4E-5*V(cc),0,v(a,k)/1.2k)}  ; added knee limit 3-17-10 sb
Gs         S         K    VALUE={limit(9.8E-5*V(sc)*LIMIT(V(S,K),0,10)/10,0,v(a,k)/800)} ; screen current was too low, added limit sb
Cg1    G    K    9.5p
Cak    A    K    4.5p
Cg1a    G    A    0.04p
.ENDS D3a
YMMV
Old 26th March 2014, 03:51 AM   #406
cogsncogs's Avatar
I got them from here:
Intactaudio
Old 26th March 2014, 04:07 AM   #407
cogsncogs's Avatar
From Andrei Frolov.
Code:
* 437A  -  IDH miniature high-transconductance triode
* Gp  P K  VALUE={(m)*limit(()*V(G,K)+V(P,K),0.0,1.0e16)^1.5}
* From WE 437A datasheet - traced on 24-03-02 by AF
.subckt 437A  P G K
    Cgp G P  3.8p
    Ci  G K  11.1p
    Co  P K  1.0p
* Modified Koren model (8 parameters): mean fit error 1.94219 mA
    Gp  P K  VALUE=
+ {(0.04402840226m)*limit(V(P,K)*log(1.0+(-0.3253203784)+exp((2.359465245)+
+ (2.359465245)*((38.12689842)+(-2617.293976m)*V(G,K))*V(G,K)/sqrt((54.35117386)^2+
+ (V(P,K)-(41.98740594))^2)))/(2.359465245),0.0,1.0e16)^(1.633336782)}
.ends 437A
Old 26th March 2014, 12:49 PM   #408
dirkwright's Avatar
Originally Posted by cogsncogs View Post
I have these two.
[/CODE]YMMV
Thanks a bunch! You guys are very helpful!
Old 29th March 2014, 03:10 PM   #409
mastajax is offline mastajax  Canada
Send a message via ICQ to mastajax Send a message via MSN to mastajax
Originally Posted by jackinnj View Post
Here are the params for the 832, Vg2=250:
All Data Points: MU=6.27 KP=44.84 EX=1.55 KVB=36.1 KG1=5476
For Vak>= 50: MU=6.86 KP=28.01 EX=1.55 KVB=24.7 KG1=4795
For Vak>=100: MU=6.90 KP=27.40 EX=1.55 KVB=38.1 KG1=4614
All of the above are dependent upon the number of points, where you choose to select them from, and how you describe the error term being minimized. This was a pretty quick rendering of the datasheet into Excel, so ymmv.
Hello, I am interested in tracing out a Chinese 832a tube amp into Multisim but I can't find any tube models in multisim... do you know where I can get the 832a and 6n2p or 12ax7 tube model? is there software I can get that will have all these already in the library?
Old 2nd April 2014, 11:41 AM   #410
artosalo is offline artosalo  Finland
artosalo's Avatar
I would be interested in having 6p36s LTspice model.
This tube seems to differ from EL500/-504 a bit.
Vacuum Tube SPICE ModelsHide this!Advertise here!
Vacuum tubes SPICE models, another way Dominique_free Software Tools 2 12th November 2013 06:26 PM
Tube spice models nhuwar Tubes / Valves 45 25th November 2011 08:47 AM
Computer program for tube curves and Spice models Jim Tonne Software Tools 9 21st November 2010 10:10 AM
Got my tube spice models, and tubed CD player page back on the air wa2ise Tubes / Valves 2 20th April 2008 11:07 PM
