Vacuum Tube SPICE Models
Old 6th December 2017, 03:23 PM   #1551
jazbo8 is offline jazbo8
jazbo8's Avatar
You are welcome, please let us know how it works out.
Old 6th December 2017, 03:25 PM   #1552
dreamth is offline dreamth  Romania
I surely will!Thank you again!
Old 7th December 2017, 05:34 PM   #1553
cogsncogs is offline cogsncogs  United States
cogsncogs's Avatar
Originally Posted by dreamth View Post
Is it possible that somebody can help me with spice model for D3A or E810F as a pentode?I would prefer it to work in ltspice but any model would be very good.
Found using search term D3A_AN.
http://www.diyaudio.com/forums/tubes...st4134400.html
Sent from my Linux desktop computer using a keyboard and a mouse.
Old 8th December 2017, 07:56 AM   #1554
Thank you! I allready made use of some models you sugested here:
It's interesting that jazbo suggested your models while you suggested his models.
So i allready tried your improved pentode model here and it works :
1V2 phono riaa preamplifier
I should try jazbo's(Nakabayashi) one too.
For the triode mode i could only hope that nakabayshi's would be more realistic than Bartola, but who knows untill real measurements are performed?
Old 10th December 2017, 04:03 PM   #1555
I tried today Nakabayashi's models and they give worse thd figures by 4...6 db which makes me trust them more.I don't really know if they are better than the others, but i preffer worse results in a sym.
Old 11th December 2017, 06:06 AM   #1556
jazbo8's Avatar
Did you have a chance to compare the simulation results with the actual circuit? It should give you an idea which model is more suitable, assuming that the tube used is close to the spec.
Old 11th December 2017, 07:48 AM   #1557
Well...i don't have a thd analyser at hand and the circuit in the link is still subject to some modifications.
Old 11th December 2017, 01:32 PM   #1558
artosalo is offline artosalo  Finland
artosalo's Avatar
Well...i don't have a thd analyser at hand...
THD analyzer = PC + FFT freeware, means practically anybody can have such in minutes.
Old 11th December 2017, 03:22 PM   #1559
I had the occasion to use Precision one and Two but never tried a soundcard.Probably will in the future as i have a professional soundcard standing on a shelf but never used it.I'm a bit clumsy when it comes to new techniques...
Old 11th December 2017, 03:28 PM   #1560
jazbo8's Avatar
There are a lot of threads on the subject here: http://www.diyaudio.com/forums/equipment-and-tools/ when you are ready to investigate.
Vacuum Tube SPICE ModelsHide this!Advertise here!
Vacuum tubes SPICE models, another way Dominique_free Software Tools 2 12th November 2013 06:26 PM
Tube spice models nhuwar Tubes / Valves 45 25th November 2011 08:47 AM
Computer program for tube curves and Spice models Jim Tonne Software Tools 9 21st November 2010 10:10 AM
Got my tube spice models, and tubed CD player page back on the air wa2ise Tubes / Valves 2 20th April 2008 11:07 PM
