Vacuum Tube SPICE Models
Old 25th October 2017, 05:11 PM   #1521
jazbo8 is offline jazbo8
jazbo8's Avatar
Default 12B4 SPICE Model
Code:
* Generic triode model: 12B4_AN
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Wed Oct 25 19:11:01 2017
*               Anode
*               | Grid
*               | | Cathode
.SUBCKT 12B4_AN A G K
BGG   GG   0 V=V(G,K)+0.99633808
BM1   M1   0 V=(0.08624954*(URAMP(V(A,K))+1e-10))**-1.1787665
BM2   M2   0 V=(0.55995921*(URAMP(V(GG)+URAMP(V(A,K))/5.1019494)+1e-10))**2.6787665
BP    P    0 V=0.0045829947*(URAMP(V(GG)+URAMP(V(A,K))/9.1112876)+1e-10)**1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.0034496543*V(M1)*V(M2)
BIG   IG   0 V=0.0022914974*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK  A    K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.0030663387*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK  G    K I=V(IG)
* CAPS
CGA   G    A 4.8p
CGK   G    K 5p
CAK   A    K 1.5p
.ENDS
Old 25th October 2017, 05:16 PM   #1522
rongon is offline rongon  United States
rongon's Avatar
That's a brand new 12B4A model. Do you think that's better than the previous one in the pctube zip file?
Old 25th October 2017, 05:21 PM   #1523
jazbo8's Avatar
Default 6T4 SPICE Model
Code:
* Generic triode model: 6T4_AN
* Version 3.10, Generated on Wed Oct 25 19:21:03 2017
*              Anode
*              | Grid
*              | | Cathode
.SUBCKT 6T4_AN A G K
BGG   GG   0 V=V(G,K)+0.51407227
BM1   M1   0 V=(0.074519235*(URAMP(V(A,K))+1e-10))**-1.502531
BM2   M2   0 V=(0.49957852*(URAMP(V(GG)+URAMP(V(A,K))/6.715333)+1e-10))**3.002531
BP    P    0 V=0.002492787*(URAMP(V(GG)+URAMP(V(A,K))/13.441997)+1e-10)**1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.0024991095*V(M1)*V(M2)
BIG   IG   0 V=0.0012463935*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK  A    K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.0015296761*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK  G    K I=V(IG)
* CAPS
CGA   G    A 1.7p
CGK   G    K 2.9p
CAK   A    K 0.2p
.ENDS
Old 25th October 2017, 05:22 PM   #1524
jazbo8's Avatar
I forgot to check, so they should be the same...
Old 25th October 2017, 10:46 PM   #1525
rongon's Avatar
They are a little bit different. Not huge differences.
First version (from pctube zip file dated March 8, 2008):
Code:
* Version 3.10, Generated on Sat Mar  8 22:41:12 2008
*                Plate
*                | Grid
*                | | Cathode
BGG   GG   0 V=V(G,K)+1
BM1   M1   0 V=(0.087065329*(URAMP(V(A,K))+1e-10))**-1.2036947
BM2   M2   0 V=(0.55479636*(URAMP(V(GG)+URAMP(V(A,K))/5.1134435)+1e-10))**2.7036947
BP    P    0 V=0.0047680512*(URAMP(V(GG)+URAMP(V(A,K))/9.2167935)+1e-10)**1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.0036584566*V(M1)*V(M2)
BIG   IG   0 V=0.0023840256*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK  A    K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.0031806909*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK  G    K I=V(IG)
* CAPS
CGA   G    A 4.8p
CGK   G    K 5p
CAK   A    K 1.5p
.ENDS
This last version (dated Oct 25, 2017):
Code:
*               Anode
*               | Grid
*               | | Cathode
BIGK  G    K I=V(IG)
* CAPS
CGA   G    A 4.8p
CGK   G    K 5p
CAK   A    K 1.5p
.ENDS
Different enough to make a difference?
Old 26th October 2017, 06:35 AM   #1526
jazbo8's Avatar
I doubt it, considering the tube tolerence. Either one should do the job.
Old 26th October 2017, 09:03 PM   #1527
rongon's Avatar
Cool. That means we have two models to use for that one type, which can be used to model slightly dissimilar triodes in an LTP, for instance, just by choosing one of each version of that type from the device menu. Works for me!
Old 29th October 2017, 09:00 PM   #1528
cogsncogs is offline cogsncogs  United States
cogsncogs's Avatar
Originally Posted by dirkwright View Post
I'm sorry, I can't find any spice models for the 6AF4 or 6T4. It looks like these are all equivalents, but I have not studied them in detail. If anyone has a model for the 6AF4 or 6T4, I'd be really happy to have it, thanks.
The 6T4 and 12B4 models posted by jazbo8 should work in TI.
Below are my 6AF4A, 6T4 and 12B4A models in Spice 3f4 format for use in TI. To use in LTspice change all instances of "^" to "**", without the quotes.
6AF4A:
Code:
* 6AF4A UHF triode Spice 3F4 model
* Modified Koren model (8 parameters) mean fit error 0.125726mA
* Traced using Curve Captor v0.9.1 by Wayne Clay on 09/30/2006
* from General Electric data sheet
*              Plate
*              | Grid
*              | | Cathode
.subckt 6AF4A  P G K
    Bp  P K  I=
+ (0.1611586566m)*uramp(V(P,K)*ln(1.0+(-0.02062628498)+exp((2.496023586)+
+ (2.496023586)*((17.06436679)+(-15.25965134m)*V(G,K))*V(G,K)/sqrt((16.25821586)^2+
+ (V(P,K)-(-0.4682646032))^2)))/(2.496023586))^(1.251660461)
  Cgp G P 2.6p ; 0.7p added
  Cgk G K 2.9p ; 0.7p added
  Cpk P K 1.9p ; 0.5p added
  Rpk P K 1G ; to avoid floating nodes
  d3  G K dx1
.model dx1 d(is=1n rs=2k cjo=1pf N=1.5 tt=1n)
.ends 6AF4A
6T4:
Code:
* 6T4 Spice 3F4 model
* Modified Koren model (8 parameters): mean fit error 0.494813mA
* Traced by Wayne Clay on 9/8/2007 using Curve Captor v0.9.1
* from Sylvania data sheet
*            Plate
*            | Grid
*            | | Cathode
.subckt 6T4  P G K
    Bp  P K  I=
+ (0.000134918778m)*uramp(V(P,K)*ln(1.0+(-0.09760272839)+exp((0.0164518854)+
+ (0.0164518854)*((1070.31832)+(78.92233257m)*V(G,K))*V(G,K)/sqrt((57.19371883)^2+
+ (V(P,K)-(8.743638001))^2)))/(0.0164518854))^(1.565722555)
    Cgp G P 2.1p ; 0.2p added
    Cgk G K 3.6p ; 0.7p added
    Cpk P K 0.45p ; 0.2p added
    d3  G K dx1
.ends 6T4
12B4A:
Code:
* 12B4A Spice 3F4 model
* Modified Koren model (8 parameters): mean fit error 0.484782mA
* Traced by Wayne Clay on 9/7/2006 using Curve Captor v0.9.1
* from General Electric datasheet.
*              Plate
*              | Grid
*              | | Cathode
.subckt 12B4A  P G K
    Bp  P K  I=
+ (0.3356616153m)*uramp(V(P,K)*ln(1.0+(-0.06344506052)+exp((4.347600947)+
+ (4.347600947)*((7.172008489)+(-12.73970121m)*V(G,K))*V(G,K)/sqrt((42.51568199)^2+
+ (V(P,K)-(19.98899827))^2)))/(4.347600947))^(1.207143141)
    Cgk G K 5.0p
    Cgp G P 4.8p
    Cpk P K 1.5p
    Rpk P K 1.0G ; to avoid floating nodes
    d3  G K dx1
.ends 12B4A
Sent from my Linux desktop computer using a keyboard and a mouse.
Old 30th October 2017, 02:49 PM   #1529
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Thanks so much!
Best Regards, Dirk
Old 30th October 2017, 08:15 PM   #1530
cogsncogs's Avatar
For those who prefer/want an Ayumi 6AF4A model.
Traced from General Electric 6AF4A datasheet.
Code:
* Generic triode model: 6AF4A
* Version 3.10, Generated on Mon Oct 30 15:55:01 2017
*                Plate
*                | Grid
*                | | Cathode
.SUBCKT 6AF4A_AN A G K
BGG   GG   0 V=V(G,K)+0.57582328
BM1   M1   0 V=(0.092328554*(URAMP(V(A,K))+1e-10))**-2.2616446
BM2   M2   0 V=(0.39876175*(URAMP(V(GG)+URAMP(V(A,K))/6.5119426)+1e-10))**3.7616446
BP    P    0 V=0.0032769425*(URAMP(V(GG)+URAMP(V(A,K))/16.330409)+1e-10)**1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.0082945898*V(M1)*V(M2)
BIG   IG   0 V=0.0016384713*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK  A    K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.0019440308*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK  G    K I=V(IG)
* CAPS
CGA   G    A 1.9p
CGK   G    K 2.2p
CAK   A    K 1.4p
.ENDS
Vacuum Tube SPICE ModelsHide this!Advertise here!
Tube spice models nhuwar Tubes / Valves 45 25th November 2011 08:47 AM
Computer program for tube curves and Spice models Jim Tonne Software Tools 9 21st November 2010 10:10 AM
Spice models stinius Solid State 0 18th November 2008 09:07 PM
Got my tube spice models, and tubed CD player page back on the air wa2ise Tubes / Valves 2 20th April 2008 11:07 PM
