Vacuum Tube SPICE Models
Old 6th October 2017, 07:10 PM   #1501
Balle Clorin is offline Balle Clorin  Norway
My secret weapon is the 6GU7
* penta6GU7 LTSpice model
* Modified Koren model (8 parameters):
* Traced by erik 25/12/2013 using Curve Captor v0.9.1
* from PENTAVAC TESTER
.subckt penta6GU7 P G K
Bp P K I=(0.06530968005m)*uramp(V(P,K)*ln(1.0+(-0.05276936784)+exp((2.050356028)+(2.050356028)*((2 9.00542735)+(-88.26359513m)*V(G,K))*V(G,K)/sqrt((30.90804259)**2+(V(P,K)-(3.024929248))**2)))/(2.050356028))**(1.285895446)
Cgk G K 0.6p ; 0.2p added
Cpk P K 3.9p ; 0.5p added
Cgp G P 3.5p ; 0.5p added
Rpk P K 1G ; to avoid floating nodes
d3 G K dx1
.model dx1 d(is=1n rs=2k cjo=1pf N=1.5 tt=1n)
.ends penta6GU7
Old 11th October 2017, 06:05 PM   #1502
My pair of Emission Labs 300B compared with Western Electric 300B datasheet curves
And thespice model.
* TML300b LTSpice model corrected by 1/2 heater volt
* Modified Koren model (8 parameters): mean fit error 0,8mA
* pentaTJ300B LTSpice model
* pentaEML300b LTSpice model
.subckt pentaEML300b P G K
Bp P K I=(0.1471360425m)*uramp(V(P,K)*ln(1.0+(-0.0836812242)+exp((14.77238937)+(14.77238937)*((4. 010010839)+(0.03955144628m)*V(G,K))*V(G,K)/sqrt((2.786333203e-006)**2+(V(P,K)-(2.303526987))**2)))/(14.77238937))**(1.48386058)
Cgk G K 8.5p ; 0.2p added
Cpk P K 4.6p ; 0.5p added
Cgp G P 15.5p ; 0.5p added
d3 G K dx1
.ends pentaEML300b
Old 12th October 2017, 11:21 AM   #1503
euro21 is offline euro21  Hungary
Originally Posted by Balle Clorin View Post
And thespice model.
Hmmm...
Old 12th October 2017, 02:51 PM   #1504
jazbo8 is offline jazbo8
jazbo8's Avatar
Make sure there is no space in the Bp line.
Old 12th October 2017, 04:33 PM   #1505
Originally Posted by euro21 View Post
Hmmm...
The text is copied directly from my LT spice INC file , and it works for me, Strange..
Old 12th October 2017, 09:57 PM   #1506
cogsncogs is offline cogsncogs  United States
cogsncogs's Avatar
This is why it's always a good idea to use the code box for models, subckts etc. Click advanced on your reply/post and you'll see the "#" button.
Like this:
Code:
  d3  G K dx1
.ends pentaEML300b
Sent from my Linux desktop computer using a keyboard and a mouse.
Old 19th October 2017, 04:16 PM   #1507
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Default 12K5 and 12U7?
Hello, I did a search and could not find spice models for tube types 12K5 and 12U7. Anyone know of one for each of these? Thanks.
Old 19th October 2017, 05:57 PM   #1508
cogsncogs's Avatar
Default 12U7 LTspice model
Here's a 12U7 model fresh from the oven. I don't have one for the 12K5. I'm assuming you need an LTspice model.
Code:
* 12U7 LTSpice model
* Modified Koren model (8 parameters): mean fit error 0.0424612mA
* Traced by Wayne Clay on 10/19/2017 using Curve Captor v0.9.1 and
* Engauge Digitizer from Sylvania datasheet
.subckt 12U7  P G K
    Bp  P K  I=
+ (0.02785936343m)*uramp(V(P,K)*ln(1.0+(-0.004710347468)+exp((0.5642928568)+
+ (0.5642928568)*((47.72916363)+(-6781.211301m)*V(G,K))*V(G,K)/sqrt((16.01863303)**2+
+ (V(P,K)-(6.398929653))**2)))/(0.5642928568))**(1.155518036)
  Cgp G P 2.2p ; 0.7p added (1.5p)
  Cgk G K 2.3p ; 0.7p added (1.6p)
  Cpk P K 0.6p ; 0.2p added (0.4p)
  d3  G K dx1
.ends 12U7
Old 19th October 2017, 06:06 PM   #1509
dirkwright's Avatar
Oh man! thanks so much! Looking forward to the 12K5 model.
I use Tina.
Best Regards,
Dirk
Old 19th October 2017, 06:43 PM   #1510
cogsncogs's Avatar
Default 12U7 model for Tina
I use Tina.
Best Regards,
Dirk
This should work in Tina. I don't have Tina on this Linux box, so I can't test it.
Code:
* 12U7 Spice 3F4 Tina model
*             Plate
*             | Grid
*             | | Cathode
.subckt 12U7  P G K
    Bp  P K  I=
+ (0.5642928568)*((47.72916363)+(-6781.211301m)*V(G,K))*V(G,K)/sqrt((16.01863303)^2+
+ (V(P,K)-(6.398929653))^2)))/(0.5642928568))^(1.155518036)
  d3  G K dx1
.ends 12U7
Vacuum Tube SPICE ModelsHide this!Advertise here!
Vacuum tubes SPICE models, another way Dominique_free Software Tools 2 12th November 2013 06:26 PM
Tube spice models nhuwar Tubes / Valves 45 25th November 2011 08:47 AM
Computer program for tube curves and Spice models Jim Tonne Software Tools 9 21st November 2010 10:10 AM
Got my tube spice models, and tubed CD player page back on the air wa2ise Tubes / Valves 2 20th April 2008 11:07 PM
