Vacuum Tube SPICE Models
Hi Koonw, I am looking for PSpice Pentode & Triode models of 1F5-G, 3D6, 6SG7. Please help, Thank You.
Disabled Account
Joined 2013
3D6 model:
Code:
* [url=http://www.dmitrynizh.com/tubeparams_image.htm]Model Paint Tools: Trace Tube Parameters over Plate Curves, Interactively[/url]
* Plate Curves image file: 3d6.png
* Data source link: <plate curves URL>
.SUBCKT 3D6 P G2 G K ; LTSpice tetrode.asy pinout
* .SUBCKT 3D6 P G K G2 ; Koren Pentode Pspice pinout
+ PARAMS: MU=8.866 KG1=3288.78 KP=33.41 KVB=76.8 VCT=-1 EX=1.4 KG2=1218 KNEE=6.451 KVC=1.611
+ KLAM=5.96E-16 KLAMG=3.723E-4 KNEE2=0.7359 KNEX=0.02344  KNK=-0.14 KNG=0.00937
+ CCG=7.5P CGP=0.3P CCP=6.5P VGOFF=-1 IGA=0.00104 IGB=0.336 IGC=37.92 IGEX=3.46
* Vp_MAX=300 Ip_MAX=30 Vg_step=1.5 Vg_start=1.5 Vg_count=15
* X_MIN=34 Y_MIN=168 X_SIZE=834 Y_SIZE=417 FSZ_X=1296 FSZ_Y=736 XYGrid=false
* Rp=1400 Vg_ac=20 P_max=4.5 Vg_qui=-9 Vp_qui=300
* showLoadLine=n showIp=y isDHP=n isPP=n isAsymPP=n isUL=n showDissipLimit=y
* showIg1=y isInputSnapped=y addLocalNFB=n
* XYProjections=n harmonicPlot=y dissipPlot=n
* UL=0.43 EG2=90 gridLevel2=y addKink=n isTanhKnee=y advSigmoid=n
RE1  7 0  1G    ; DUMMY SO NODE 7 HAS 2 CONNECTIONS
E1   7 0  VALUE=  ; E1 BREAKS UP LONG EQUATION FOR G1.
+{V(G2,K)/KP*LOG(1+EXP((1/MU+(VCT+V(G,K))/SQRT(KVB+V(G2,K)*V(G2,K)))*KP))}
RE2  6 0  1G    ; DUMMY SO NODE 6 HAS 2 CONNECTIONS
E2  6 0  VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))} ; Kg1 times KIT current
G1   P K  VALUE={V(6)/KG1*ATAN((V(P,K)+KNEX)/KNEE)*TANH(V(P,K)/KNEE2)*(1+KLAMG*V(P,K))+KLAM*V(P,K)}
* Alexander Gurskii screen current, see audioXpress 2/2011
RE4K 4K K 1G ; Dummy, per Alex request
E4K 4K  4 VALUE={0} ; Dummy, per Alex request
G4K 4K K VALUE={V(6)/KG2*(KVC-ATAN((V(P,K)+KNEX)/KNEE)*TANH(V(P,K)/KNEE2))/(1+KLAMG*V(P,K))}
RCP  P K  1G     ; FOR CONVERGENCE
C1   K G  {CCG}  ; CATHODE-GRID 1
C2   G P  {CGP}  ; GRID 1-PLATE
C3   K P  {CCP}  ; CATHODE-PLATE
RE23 G 0 1G
GG G K VALUE={(IGA+IGB/(IGC+V(P,K)))*(MU/KG1)*
+(PWR(V(G,K)-VGOFF,IGEX)+PWRS(V(G,K)-VGOFF,IGEX))}
.ENDS
Disabled Account
Joined 2013
I don't make triode model separately but with the Pentode (Tetrode) model. Just connect the screen to plate this will make triode mode. So you can plot it out with DC Sweep. The plate and screen current is added together for triode mode.
Disabled Account
Joined 2013
6SG7 model:
Code:
* [URL="http://www.dmitrynizh.com/tubeparams_image.htm"]www.dmitrynizh.com/tubeparams_image.htm[/URL]
* Plate Curves image file: 6sg7.png
.SUBCKT 6SG7 P G2 G K ; LTSpice tetrode.asy pinout
* .SUBCKT 6SG7 P G K G2 ; Koren Pentode Pspice pinout
+ PARAMS: MU=48.75 KG1=706.16 KP=40.28 KVB=36.69 VCT=-1.648 EX=1.61 KG2=865.83 KNEE=13.03 KVC=2.213
+ KLAM=7.226E-11 KLAMG=6.961E-5 KNEE2=5.919 KNEX=0.0525  KNK=-0.044 KNG=0.006
+ CCG=8.5P CGP=0.003P CCP=7P VGOFF=-0.6 IGA=0.001 IGB=0.3 IGC=8 IGEX=2
* Vp_MAX=500 Ip_MAX=12.5 Vg_step=2 Vg_start=0 Vg_count=20
* X_MIN=75 Y_MIN=105 X_SIZE=556 Y_SIZE=562 FSZ_X=1296 FSZ_Y=736 XYGrid=false
* Rp=1400 Vg_ac=20 P_max=3 Vg_qui=-19 Vp_qui=300
* UL=0.43 EG2=100 gridLevel2=y addKink=n isTanhKnee=y advSigmoid=n
RE23 G 0 1G
.ENDS
Disabled Account
Joined 2013
1f5g model:
Code:
*** 1F5G ******************************************
* Created on 06/22/2021 11:18 using paint_kip.jar
* Plate Curves image file: 1f5g.png
.SUBCKT 1F5G P G2 G K ; LTSpice tetrode.asy pinout
* .SUBCKT 1F5G P G K G2 ; Koren Pentode Pspice pinout
+ PARAMS: MU=12.8 KG1=5588 KP=122.38 KVB=12 VCT=0.2 EX=1.4 KG2=16296 KNEE=8.532 KVC=2.236
+ KLAM=2.5E-8 KLAMG=6.48E-4 KNEE2=26.13 KNEX=69.3  KNK=-0.044 KNG=0.006 KNPL=50 KNSL=11 KNPR=120 KNSR=29
+ CCG=3P CGP=1.4P CCP=1.9P VGOFF=-0.6 IGA=0.001 IGB=0.3 IGC=8 IGEX=2
* Vp_MAX=400 Ip_MAX=20 Vg_step=3 Vg_start=0 Vg_count=9
* X_MIN=36 Y_MIN=113 X_SIZE=803 Y_SIZE=404 FSZ_X=1296 FSZ_Y=736 XYGrid=false
* Rp=1400 Vg_ac=20 P_max=1.75 Vg_qui=-12 Vp_qui=300
* UL=0.43 EG2=135 gridLevel2=y addKink=y isTanhKnee=y advSigmoid=n
RE21 21 0 1
E21  21 0 VALUE={V(6)/KG1*ATAN((V(P,K)+KNEX)/KNEE)*TANH(V(P,K)/KNEE2)} ; Ip with knee but no slope and no kink
RE22 22 0 1 ; E22: kink curr deviation for plate
E22  22 0 VALUE={V(21)*LIMIT(KNK-V(G,K)*KNG,0,0.3)*(-ATAN((V(P,K)-KNPL)/KNSL)+ATAN((V(P,K)-KNPR)/KNSR))}
G1   P  K  VALUE={V(21)*(1+KLAMG*V(P,K))+KLAM*V(P,K) + V(22)}
* Alexander Gurskii screen current, see audioXpress 2/2011, with slope and kink added
RE43 43 K 1G ; Dummy
E43  43 G2 VALUE={0} ; Dummy
G2   43 K  VALUE={V(6)/KG2*(KVC-ATAN((V(P,K)+KNEX)/KNEE)*TANH(V(P,K)/KNEE2))/(1+KLAMG*V(P,K))-V(22)}
RE23 G 0 1G
.ENDS
Hi all,
I worked the last weeks on a new generic Triode version of mine, the version i5. It has a more accurate grid current model, which will be noticeable in high-gm triodes.
I experienced that weak points are better found, when somebody else but not the inventor does test a new thing.
So, is there anybody who would like to test my PhilipsECG 6922 i5 prototype?
You can just play with it - including "misuse" like connected in wrong way, overdrive it, etc. :rolleyes:
Any convergence problems or obviously wrong result would awake my interest ;)
Adrian
Anything I can do to help. I have plenty of modeled circuits using 6DJ8 which I can change to torture the i5 model. How about trying contact potential biasing? Perhaps running the model with very low grid-cathode voltage on the order of -0.7V? With an actual 6DJ8 that should induce some grid current. I can send screenshots of error messages, etc.
