Vacuum Tube SPICE Models
Old 6th January 2017, 04:26 PM   #1291
jazbo8 is offline jazbo8
jazbo8's Avatar
Try searching this thread, I think cogsncogs made one that's quite accurate - better than Ayumi's version.
Old 8th January 2017, 04:47 PM   #1292
cogsncogs is offline cogsncogs  United States
cogsncogs's Avatar
Default 12AX7A/ECC83 model
Originally Posted by ygg-it View Post
Hello, I've found several models of 12AX7/ECC83 over internet.
Which is the most reliable you ever found? Can you please post here the best?
Don't know about the "best", but it's close...
Code:
* 12AX7A-mz LTSpice model
* Rydel model (5 parameters): mean fit error 0.0364781mA
* Traced by Wayne Clay on 10/01/2006 using Curve Captor v0.9.1
* from Mazda Belvu data sheet
.subckt 12AX7A-mz  P G K
  Bp  P K  I=((0.001162961073m)+(0.0001179305949m)*V(G,K))*uramp
+ ((89.27317344)*V(G,K)+V(P,K)+(50.06656412))**1.5 * V(P,K)/(V(P,K)+(1.191219264))
  Cgk G K 2.3p ; 0.7p added (1.6p)
  Cgp G P 2.3p ; 0.7p added (1.6p)
  Cpk P K 0.53p ; 0.2p added (0.33p)
  Rpk P K 1G ; to avoid floating nodes
  d3  G K dx1
.model dx1 d(is=1n rs=2k cjo=1pf N=1.5 tt=1n)
.ends 12AX7A-mz
Sent from my Linux desktop computer using a keyboard and a mouse.
Old 17th January 2017, 12:26 PM   #1293
RajkoM is online now RajkoM  Bosnia and Herzegovina
RajkoM's Avatar
If someone needs triode curves of E83F, here are (page 477).
Great tube, btw.
http://pessina.mib.infn.it/WOLTE2014...%201956%20.pdf
Old 18th January 2017, 10:06 AM   #1294
211hojbjerg is offline 211hojbjerg  Denmark
Hi All,
I'm looking for a pentode model of a PL802/EL802.
Best
Karsten
Old 20th January 2017, 09:32 AM   #1295
jazbo8's Avatar
Default PL802 SPICE Model
A bit crude, but should work, try and stay away from low bias...
Code:
* Generic pentode model: PL802_AN
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Fri Jan 20 10:26:10 2017
*                Anode
*                | Screen Grid
*                | |  Control Grid
*                | |  |  Cathode
.SUBCKT PL802_AN A G2 G1 K
BGG   GG   0 V=V(G1,K)+0.003190568
BM1   M1   0 V=(0.0054900589*(URAMP(V(G2,K))+1e-10))**-0.66524575
BM2   M2   0 V=(0.69276201*(URAMP(V(GG)+URAMP(V(G2,K))/55.962604)))**2.1652458
BP    P    0 V=0.040273246*(URAMP(V(GG)+URAMP(V(G2,K))/80.78186))**1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.023448349*V(M1)*V(M2)
BIG   IG   0 V=0.020136623*URAMP(V(G1,K))**1.5*(URAMP(V(G1,K))/(URAMP(V(A,K))+URAMP(V(G1,K)))*1.2+0.4)
BIK2  IK2  0 V=V(IK,IG)*(1-0.4*(EXP(-URAMP(V(A,K))/URAMP(V(G2,K))*15)-EXP(-15)))
BIG2T IG2T 0 V=V(IK2)*(0.83282327*(1-URAMP(V(A,K))/(URAMP(V(A,K))+10))**1.5+0.16717673)
BIK3  IK3  0 V=V(IK2)*(URAMP(V(A,K))+3430)/(URAMP(V(G2,K))+3430)
BIK4  IK4  0 V=V(IK3)-URAMP(V(IK3)-(0.020886747*(URAMP(V(A,K))+URAMP(URAMP(V(G2,K))-URAMP(V(A,K))))**1.5))
BIP   IP   0 V=URAMP(V(IK4,IG2T)-URAMP(V(IK4,IG2T)-(0.020886747*URAMP(V(A,K))**1.5)))
BIAK  A    K I=V(IP)+1e-10*V(A,K)
BIG2  G2   K I=URAMP(V(IK4,IP))
BIGK  G1   K I=V(IG)
* CAPS
CGA   G1  A  0.075p
CGK   G1  K  12p
C12   G1  G2 8p
CAK   A   K  4p
.ENDS
Old 20th January 2017, 03:16 PM   #1296
n4pum is offline n4pum  United States
Default 6JE6C/6LQ6/6JM6 best fit model
A little tweet on EL509 model seems to work the data shows it fits. Modeling an old SBE SB1/2-LA HF sweep tube Linear Amplifier. LTSpice fun project to look at.
Old 27th January 2017, 01:15 PM   #1297
ygg-it is offline ygg-it  Italy
ygg-it's Avatar
Originally Posted by jazbo8 View Post
Beam Tetrode SPICE Model:
Code:
* Generic pentode model: KT77_AN
* Version 3.10, Generated on Fri Jan 06 09:44:09 2017
*               Anode
*               | Screen Grid
*               | |  Control Grid
*               | |  |  Cathode
.SUBCKT KT77_AN A G2 G1 K
BGG   GG   0 V=V(G1,K)+0.99969437
BM1   M1   0 V=(0.01275965*(URAMP(V(G2,K))+1e-10))**-0.23213508
BM2   M2   0 V=(0.86598327*(URAMP(V(GG)+URAMP(V(G2,K))/10.503167)))**1.7321351
BP    P    0 V=0.0024912955*(URAMP(V(GG)+URAMP(V(G2,K))/12.128603))**1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.0016155279*V(M1)*V(M2)
BIG   IG   0 V=0.0012456477*URAMP(V(G1,K))**1.5*(URAMP(V(G1,K))/(URAMP(V(A,K))+URAMP(V(G1,K)))*1.2+0.4)
BIG2T IG2T 0 V=V(IK2)*(0.916000233*(1-URAMP(V(A,K))/(URAMP(V(A,K))+10))**1.5+0.083999767)
BIK3  IK3  0 V=V(IK2)*(URAMP(V(A,K))+4250)/(URAMP(V(G2,K))+4250)
BIK4  IK4  0 V=V(IK3)-URAMP(V(IK3)-(0.0015600239*(URAMP(V(A,K))+URAMP(URAMP(V(G2,K))-URAMP(V(A,K))))**1.5))
BIP   IP   0 V=URAMP(V(IK4,IG2T)-URAMP(V(IK4,IG2T)-(0.0015600239*URAMP(V(A,K))**1.5)))
BIGK  G1   K I=V(IG)
* CAPS
CGA   G1  A  1p
CGK   G1  K  10.2p
C12   G1  G2 6.8p
CAK   A   K  9p
.ENDS
Triode-Connected SPICE Model:
Code:
* Generic triode model: KT77_T_AN
* Version 3.10, Generated on Fri Jan 06 09:43:42 2017
*                 Anode
*                 | Grid
*                 | | Cathode
.SUBCKT KT77_T_AN A G K
BGG   GG   0 V=V(G,K)+0.99969437
BM1   M1   0 V=(0.01275965*(URAMP(V(A,K))+1e-10))**-0.23213508
BM2   M2   0 V=(0.86598327*(URAMP(V(GG)+URAMP(V(A,K))/10.503167)+1e-10))**1.7321351
BP    P    0 V=0.0024912955*(URAMP(V(GG)+URAMP(V(A,K))/12.128603)+1e-10)**1.5
BIG   IG   0 V=0.0012456477*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK  A    K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.0015600239*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK  G    K I=V(IG)
* CAPS
CGA   G    A 1p
CGK   G    K 17p
CAK   A    K 9p
.ENDS
Hi, can I use the penthode KT77_AN model in a triode connection? I saw it works pretty well also in triode design in LTspice!
Or is it only reccomended to use the KT77_T_AN for the triode connection?
Thanks!
Old 27th January 2017, 01:32 PM   #1298
jazbo8's Avatar
Either one will work, depending on which symbol you want to use in the simulation.
Old 28th January 2017, 09:21 PM   #1299
tbarnettsgf is offline tbarnettsgf
Does anyone have a model for Pentode 6jn6?
http://www.mif.pg.gda.pl/homepages/f...123/6/6JN6.pdf
Old 29th January 2017, 07:02 AM   #1300
jazbo8's Avatar
See http://www.diyaudio.com/forums/tubes...eded-6jn6.html
Vacuum Tube SPICE ModelsHide this!Advertise here!
Tube spice models nhuwar Tubes / Valves 45 25th November 2011 09:47 AM
Computer program for tube curves and Spice models Jim Tonne Software Tools 9 21st November 2010 11:10 AM
Spice models stinius Solid State 0 18th November 2008 10:07 PM
Got my tube spice models, and tubed CD player page back on the air wa2ise Tubes / Valves 2 21st April 2008 12:07 AM
Copyright ©1999-2017 diyAudio
