Vacuum Tube SPICE Models
Old 22nd December 2013, 08:54 AM   #121
RajkoM is offline RajkoM  Bosnia and Herzegovina
RajkoM's Avatar
I do not. Philips did not give it.
Old 22nd December 2013, 10:45 AM   #122
jazbo8 is offline jazbo8
jazbo8's Avatar
Default Philips 18040 Model
I used 18046's triode data and fudged it to fit 18040's curves, and the SPICE model is shown below, please test it. 18040's datasheet indicates that the maximum Vg1 is -1.3V, perhaps that's why the 0V and -1V curves were not fully visible.
Code:
* Generic pentode model: 18040_AN
* Copyright 2003-2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Sun Dec 22 12:36:57 2013
*                Plate
*                | Screen Grid
*                | |  Control Grid
*                | |  |  Cathode
.SUBCKT 18040_AN A G2 G1 K
BGG   GG   0 V=V(G1,K)+-0.083801857
BM1   M1   0 V=(0.0081798859*(LIMIT(V(G2,K),0,1e16)+1e-10))**-0.49067171
BM2   M2   0 V=(0.7535145*(LIMIT(V(GG)+LIMIT(V(G2,K),0,1e16)/30.133122,0,1e16)))**1.9906717
BP    P    0 V=0.0067112265*(LIMIT(V(GG)+LIMIT(V(G2,K),0,1e16)/39.990102,0,1e16))**1.5
BIK   IK   0 V=IF(V(GG)>0,1,0)*V(P)+(1-IF(V(GG)>0,1,0))*0.003878634*V(M1)*V(M2)
BIG   IG   0 V=0.0033556133*LIMIT(V(G1,K),0,1e16)**1.5*(LIMIT(V(G1,K),0,1e16)/(LIMIT(V(A,K),0,1e16)+LIMIT(V(G1,K),0,1e16))*1.2+0.4)
BIK2  IK2  0 V=V(IK,IG)*(1-0.4*(EXP(-LIMIT(V(A,K),0,1e16)/LIMIT(V(G2,K),0,1e16)*15)-EXP(-15)))
BIG2T IG2T 0 V=V(IK2)*(0.78812548*(1-LIMIT(V(A,K),0,1e16)/(LIMIT(V(A,K),0,1e16)+10))**1.5+0.21187452)
BIK3  IK3  0 V=V(IK2)*(LIMIT(V(A,K),0,1e16)+15630)/(LIMIT(V(G2,K),0,1e16)+15630)
BIK4  IK4  0 V=V(IK3)-LIMIT(V(IK3)-(0.0036089138*(LIMIT(V(A,K),0,1e16)+LIMIT(V(G2,K),0,1e16)-LIMIT(V(A,K),0,1e16))**1.5),0,1e16)
BIP   IP   0 V=LIMIT(V(IK4,IG2T)-LIMIT(V(IK4,IG2T)-(0.0036089138*LIMIT(V(A,K),0,1e16)**1.5),0,1e16),0,1e16)
BIAK  A    K I=V(IP)+1e-10*V(A,K)
BIG2  G2   K I=LIMIT(V(IK4,IP),0,1e16)
BIGK  G1   K I=V(IG)
* CAPS
CGA   G1  A  0.02p
CGK   G1  K  9p
C12   G1  G2 6p
CAK   A   K  7.5p
.ENDS
Old 22nd December 2013, 11:57 AM   #123
RajkoM's Avatar
Great jazbo8. Thank you very much, I appreciate it.
I saw before triode characteristics of 18046 and considering the very similar data with 18040. I presumed that they could be taken into account.
Thanks again.
Best diying.
Old 22nd December 2013, 03:07 PM   #124
popilin is offline popilin  Argentina
popilin's Avatar
When I had all the answers, they changed me the questions...
Ayumi Nakabayashi models are very accurate, I could check through the average plate characteristic curves, and average transfer caracteristics curves.
However, in simulations, distortion is 10 dB greater than with Norman Koren models.
To remove doubt, I simulated the circuit proposed by Morgan Jones, again with Norman Koren models the results are consistent (+ - 1 dB) while with Ayumi Nakabayashi models, distortion is always about 10 dB higher.
The million dollar question is: if the valves are defined by their curves, why with more precise curves less accurate results are obtained?
I do not suffer from insanity, I enjoy every minute of it. - Edgar Allan Poe
He has the most who is most content with the least. - Diogenes of Sinope
Old 22nd December 2013, 04:20 PM   #125
jazbo8's Avatar
@Rajkom - You are welcome, hope it is close enough for simulation purpose.
@popilin - Which models did you use? Perhaps we can doubt check the results, 10dB difference seems a bit excessive...
Old 22nd December 2013, 04:41 PM   #126
popilin's Avatar
Yesterday I tried 5687, 6CG7, 6SN7...all the same, 10 dB greater THD.
Thanks.
Old 22nd December 2013, 04:50 PM   #127
jazbo8's Avatar
So 10dB more distortion vs. actual circuit measurements? Could you please post the schematics or links if possible?
Old 22nd December 2013, 05:40 PM   #128
kevinkr's Avatar
I'd be happy to curve trace some in both pentode and triode connection, but have none just yet. (It's a new type to me) I just purchased 4 on eBay out of curiosity, and I will test them and post the results here once I get them.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 22nd December 2013, 05:48 PM   #129
kevinkr's Avatar
Originally Posted by popilin View Post
<snip>
Did you actually measure any of the tubes in the circuit you based the simulations on?
I typically measure at least 10dB more distortion in an actual circuit than in a simulation using the Koren models. (My latest phono stage design shows this clearly) Could it be that the Ayumi models are getting closer to the truth?
The tools I use to generate models are all based on the Koren equations. (paint_kip, paint_kit, and the uTracer alternate gui) Eventually I will learn the Ayumi method and see how that works.
Old 22nd December 2013, 05:51 PM   #130
popilin's Avatar
Vacuum Tube SPICE ModelsHide this!Advertise here!
Tube spice models nhuwar Tubes / Valves 45 25th November 2011 08:47 AM
Computer program for tube curves and Spice models Jim Tonne Software Tools 9 21st November 2010 10:10 AM
Spice models stinius Solid State 0 18th November 2008 09:07 PM
Got my tube spice models, and tubed CD player page back on the air wa2ise Tubes / Valves 2 20th April 2008 11:07 PM
